help please - JeepForum.com
post #1 of 12 Old 04-03-2012, 07:30 PM Thread Starter
jdupray
help please
i have put three serpenting belts on my 2003 jeep wrangler se. i have replaced the tensioner pullie and 2 of the idler no slack pullies but it keeps shredding the belt. it runs fine. has all the power but when it sits and then gets started. within 5 mins the belt shredds. can anyone help me i have spent enough money on this and just want it fixed
jdupray is offline
post #2 of 12 Old 04-03-2012, 07:35 PM
cheapjeep06
Sounds like a pulley is either bent or out of line with the rest. Saw this on the ex's minivan...kept shredding the belts.
Remove the belt, then stand to the side to see if you can tell which pulley is off. Staight piece of metal will help. Or the belts weren't installed completely on the crank pulley(easiest one to not get on right), which will chew up and spit out the belt.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #3 of 12 Old 04-03-2012, 07:37 PM
2jhanna
are you saying that if the vehicle sits for a while and is then started, then the belt shreds ?
have you checked the alignment of the other pulleys ? is 1 pulley sticking out or further in than the rest ?
jhanna
denton county, tx
2jhanna is offline
post #4 of 12 Old 04-03-2012, 07:39 PM Thread Starter
jdupray
it slides around on the tensioner pully. it will come out far enough to hang off the pully and rub on the tensioner itself
jdupray is offline
post #5 of 12 Old 04-03-2012, 07:40 PM Thread Starter
jdupray
it will run for a while then the next morning when it is started within 20 mins of driving it shreds
jdupray is offline
post #6 of 12 Old 04-03-2012, 07:42 PM
cheapjeep06
Forgot to tell you to try to turn every pulley by hand after you take off the belt...perhaps the a/c or power steering pump pulley is dragging or has bad bearings.
Is there a crack in the fan pulley? (shot in the dark)
post #7 of 12 Old 04-03-2012, 07:48 PM
cheapjeep06
OK, just read your post about moving on the tensioner. Sounds like something is not lined up right. I see this at work all the time when pulley are not lined up perfectly. The ribs try to hold the belt in place, but the tensioner, idler, and waterpump/fan pulley are smooth and run off the "back" of the belt.
post #8 of 12 Old 04-03-2012, 07:54 PM Thread Starter
jdupray
how can i tell which pully is out of line?
jdupray is offline
post #9 of 12 Old 04-03-2012, 07:54 PM
2jhanna
sounds like the idler (or bracket) is not perpendicular. meaning that the pulley surface is at an angle.
jhanna
denton county, tx
2jhanna is offline
post #10 of 12 Old 04-03-2012, 07:55 PM Thread Starter
jdupray
it runs for a while. i have driven it for 30 miles no bad sounds or anything. then i just started it to run to the store and within 10 miles it shredded the belt
jdupray is offline
post #11 of 12 Old 04-03-2012, 09:06 PM
JPNinPA
Video!! Pics
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #12 of 12 Old 04-03-2012, 09:44 PM
mg2380
Same thing was happening to me. Turned out I left a box of open razors and Christmas ornaments in my engine compartment.
mg2380 is offline
belt , help needed , please help , serpentine belt
