Help for newbie female jeeper. TJ Bad Acceleration - Page 2 - JeepForum.com
post #16 of 35 Old 03-10-2015, 11:45 AM Thread Starter
IRISTJ
Originally Posted by CoachDad View Post
I would suggest looking under "feline psychiatry" in the yellow pages.
I will tap it to see what I hear....hopefully more than meow. BTW nothing on the yellow pages regarding cats psyche, though their urine does smell somewhat like sulfur .
IRISTJ is offline
post #17 of 35 Old 03-10-2015, 11:59 AM
Olsen
Junior Member
Nice oneup! You go IRISJ
Olsen is offline
post #18 of 35 Old 03-10-2015, 12:11 PM Thread Starter
IRISTJ
It may be worthwhile mentioning the master/slave assembly was replaced recently and works goody-go, so that can be ruled out.
IRISTJ is offline
post #19 of 35 Old 03-10-2015, 04:25 PM
ravenworks
This would be the first thing you should check,this sounds as if your clutch is slipping.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #20 of 35 Old 03-11-2015, 09:11 AM Thread Starter
IRISTJ
Hey guys!
So here's what I did last night. Not successfully finding any hills to try the aforementioned I went with option two: put it in 4rd gear with the e-brake on and slowly let the clutch out, no stall, truck just rev'd up and didn't attempt to move almost at all. Also tried it in third gear with very little bite, no stall. I think you nailed it in that it's definitely the clutch that's gone belly up...
If anyone knows any good links to a good step-by-step process to changing the clutch it would be fathoms appreciated!! Many thanks all.
IRISTJ is offline
post #21 of 35 Old 03-11-2015, 10:40 AM
kmas0n
http://www.4x4xplor.com/clutch.html
This is a great site for our jeeps, lots of tech
kmas0n is offline
post #22 of 35 Old 03-11-2015, 11:30 AM Thread Starter
IRISTJ
Great article, very well laid out with pics and all. I'll let you all know how the this turns out Thank you!!!
IRISTJ is offline
post #23 of 35 Old 03-18-2015, 11:53 AM Thread Starter
IRISTJ
Anyone has any horror stories with the two torx bolts on top of the transmission? Impact wrench was no bueno. Looks like I will be in further need of male elbow grease....blah
IRISTJ is offline
post #24 of 35 Old 03-19-2015, 06:25 AM
Jeepster83
If you have the trans cross member/skid plate out you can lower the back of the trans and get to the more easily with the proper reverse torx and a good ratchet and a long extension. Trying to reach between the trans and firewall is a knuckle busting experience.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #25 of 35 Old 03-19-2015, 06:34 AM
crkid
Have you checked your brakes to make sure they're not dragging or stuck? Just had that happen to me.
crkid is offline
post #26 of 35 Old 03-19-2015, 07:53 AM
marka2k
2006 WK
Just replaced my clutch and transmission, in my opinion this is the best way to get to the two bolts up top.
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #27 of 35 Old 03-25-2015, 11:50 AM Thread Starter
IRISTJ
Definitely not the brakes. First and second are half decent, on third and fourth it goes nowhere. Thanks for checking in tho
IRISTJ is offline
post #28 of 35 Old 03-25-2015, 11:53 AM Thread Starter
IRISTJ
Got them out! but let me paraphrase... a good ratchet and a long a$$ extension
IRISTJ is offline
post #29 of 35 Old 03-27-2015, 07:59 AM
CoachDad
I hope you're having success. Enlist some quality help when lining up the trans to the flywheel/engine. It can be a bit of a bear.
CoachDad is offline
post #30 of 35 Old 03-27-2015, 10:31 AM
Jeepster83
As long as you keep the dowl pins where they need to be then aligning the engine and trans is a fairly easy process. Put a bolt in to hold the two together and put the engine on its mounts. Then go back to the bell housing bolts, then the torque converter. Blue loctite is your friend on the torque converter bolts.
acceleration , slow
