help new crate motor not starting - JeepForum.com
post #1 of 7 Old 01-24-2011, 06:46 PM Thread Starter
warnerwrangler
I have a 2001 tj sport so its a 4.0 with a manual transmisson. i recently purchased a new jasper motor 4.0 to replace my old one. We have the motor installation complete but its not starting. We do have oil pressure, gas and spark. What we dont have down is the timing. From what Ive read it usually comes down to the cam postion sensor< not sure if thats the name but its located where the distributor usually is>. From other posts ive also heard about markings on the balancer but on my motor there are none. The people that are helping me are very knowledgable on carburated motor not sooo much on fuel injected... Any tips would be helpful thank you
warnerwrangler is offline
post #2 of 7 Old 01-24-2011, 07:24 PM
lope
lope's Avatar
I'm not familiar with the particular '01 setup but you should be able to turn crankshaft to TDC and verify that your cam sensor is in the right location in relation to TDC. Good luck
lope is offline
post #3 of 7 Old 01-24-2011, 07:58 PM Thread Starter
warnerwrangler
We were able to get the motor to TDC by removing the spark plug. However the cam sensor is the puzzling part for us. How do we know thats in the right postion.
post #4 of 7 Old 01-24-2011, 10:14 PM
lope
lope's Avatar
After looking around on the web a little, it appears the '01 still has a distributor with a rotor. You'll need the rotor to be at the #1 plug on the distributor cap.
lope is offline
post #5 of 7 Old 01-24-2011, 10:23 PM
BON
Put engine at tdc take out distributor and cam sensor there should be a hole on bottom of dist and a couple like 3 on the plastic under where cam sensor put something thru plastic and dist like a nail to lock it and install dist back and should start right up
BON is offline
post #6 of 7 Old 01-25-2011, 01:32 AM
rlk_99
If you dont have the conventional cap and rotor and have the coil rail like the 02's have then you need to pull the pick up, set the oil pump drive to the 10 o'clock position and bring cylinder #1 up to top dead center (TDC). Once that is set then you have to look at the pick up itself. In the area that the sensor bolts there is a whole. It is at the very bottom and you'll have to look VERY close to find it. Once youve found it line up the whole in the bottom of the tone ring with it and use something like a pin or a small cotter key to lock it in place. If everything is set right then it should drop right into place and fire up.
'02 Sport..... Stock no more.... RE 3.5 SF, RE adjustable trackbar(F/R) and 33x12.50x15 BFG MT's installed
rlk_99 is offline
post #7 of 7 Old 01-25-2011, 03:54 AM Thread Starter
warnerwrangler
thanks everyone for your responses ill have to try it this afternoon
cps , motor , not starting , timing
possible problem with brand new ATK crate motor? suresperance TJ Wrangler Technical Forum 18 10-31-2010 10:20 PM
Best place to buy a 4.0L crate motor BigMikeATL Wrangler General Discussion 4 10-07-2009 11:17 AM
Texas Engine Builder or Crate Motor? andrewbranch06 YJ Wrangler Technical Forum 2 10-04-2009 09:01 AM
Crate Motor Question jeepaholic91 YJ Wrangler Technical Forum 3 07-16-2009 08:59 AM
chevy 305 crate motor swap jeffrey919r1 YJ Wrangler Technical Forum 17 10-06-2008 12:36 PM
