Help! Mystery Nut! - JeepForum.com
post #1 of 12 Old 07-29-2012, 11:24 AM Thread Starter
zdhutson
Help! Mystery Nut!
This nut fell out of my 01 this morning. I started up the Jeep this morning and it fell out. It was laying under the skid plate, more rear than forward. I drove about fifteen or twenty miles and it drove fine. When I got to my dad's house, I crawled under and couldn't find anywhere that it could have fallen from. I think the nut is 1 1/2 in. It is bigger then 1 1/4 in, that was the biggest wrench in the garage here. As the pictures show, it's some kind of a stop-nut. So does anyone recognize it or have any ideas...? Thanks guys.
zdhutson is offline
post #2 of 12 Old 07-29-2012, 11:37 AM
MattJeep
2003 WJ
Some type of exhaust nut? Or maybe it got kicked up into your Jeep? Idk, doesn't look familiar.
edit: O2 bung?
MattJeep is offline
post #3 of 12 Old 07-29-2012, 11:43 AM Thread Starter
zdhutson
Thanks a lot! I'll check that out. You might be right about it being kicked up from somewhere else. It looked a lot bigger than anything I have ever seen under the Wrang.
zdhutson is offline
post #4 of 12 Old 07-29-2012, 11:53 AM
0blcktj6
edit: O2 bung?
That was my first thought as well...
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
0blcktj6 is offline
post #5 of 12 Old 07-29-2012, 01:09 PM
silver97tj
silver97tj's Avatar
Hi all
The nut has an inner lip, more like the ones that hold fluid lines or sensor............
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #6 of 12 Old 07-29-2012, 01:11 PM
0blcktj6
^Touche good sir
My Build Thread:
0blcktj6 is offline
post #7 of 12 Old 07-29-2012, 01:21 PM
TJJP77
TJJP77's Avatar
edit: O2 bung?
O2 bungs are welded into the pipe normally.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #8 of 12 Old 07-29-2012, 01:32 PM
gmiller0737
I don't think it came from your Jeep Tht looks like a nut that would be on something like a a/c line they do not come off unless the line is cut It was likely kicked up on the road.
gmiller0737 is offline
post #9 of 12 Old 07-29-2012, 03:03 PM
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
I agree, a few weeks ago I replaced the clutch in my 06, so I had the skid plate off, tranny and tcase out, so I had a pretty good view of just about everything up and under there and it doesn't look like anything I remember seeing. But I did find about 5 pounds of dirt, sand and rocks on the inside of my skid plate, so I'd be willing to bet it wound up up there.
Eric
RAAB3485 is offline
post #10 of 12 Old 07-29-2012, 03:10 PM
kkhrod
I just installed a long arm lift a few weeks back, so needless to say I've been under my Jeep a number of hours to install and go through and re tighten. I haven't seen any nut that resembles the one you have pictured. A case of a kicked up nut.
kkhrod is offline
post #11 of 12 Old 07-29-2012, 04:18 PM
alittleoff
It looks galvanized, probably plumbing road kill. I just wonder if those are safety wire loops?
All slow and no show
alittleoff is offline
post #12 of 12 Old 07-30-2012, 04:46 AM Thread Starter
zdhutson
Thanks a lot guys. I thought (and hoped) it was foreign. It looked too big to be from the Jeep. I replaced the clutch twice back in Jan/Feb, and I wondered if it could be from that. But I guess not, thank God!
Currently: 2007 X: 2 Door, Steel Blue Metallic, Manual, Skyjacker 2.5" lift, Nitro 4.56 gears, 35x12.50x15 Grabber 2
Formerly: 2001 Sport: Black, Manual, D44, Stock on 31s but lovingly abused (I loved that rig.)
KCCO
zdhutson is offline
mystery , nut , tj
Mystery box?? vmaxup TJ Wrangler Technical Forum 3 08-30-2011 09:18 AM
2.5 Mystery Alabamaranger YJ Wrangler Technical Forum 7 01-11-2011 08:43 PM
D44 Mystery MikeRi24 TJ Wrangler Technical Forum 10 02-22-2009 11:23 AM
Mystery LED Jetmech143 TJ Wrangler Technical Forum 8 07-08-2006 07:32 PM
Yj mystery..... 4x4punk YJ Wrangler Technical Forum 11 11-03-2004 07:42 AM
