Help! My TJ has low idle and shuts off - JeepForum.com
post #1 of 10 Old 12-06-2007, 08:29 AM Thread Starter
Sky Hye
Sky Hye's Avatar
Hey Guys. This problem has been getting more frequent. When I am at a stoplight or parked, My idle is very low, and it kinda feels like it is about to stall.
Whenever I shift the tranny, or put it in reverse, the jeep sometimes stalls.
Its an auto with about 38k miles. Could it be a fuel filter? Tranny fluid? Something else? PLease help, its getting to be a problem. Thanks
Sky Hye is offline
post #2 of 10 Old 12-06-2007, 09:22 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Try cleaning your IAC (Idle Air Controller) with throttle body cleaner and a toothbrush. Do a search using my name and IAC cleaning where you'll find a more detail, I'm on my way up to Los Angeles for a meeting.
Jerry Bransford is online now
post #3 of 10 Old 12-06-2007, 09:46 AM Thread Starter
Sky Hye
Sky Hye's Avatar
Great, Thanks Jerry. I will Give it a shot this afternoon and ofcourse if it doesnt help, I'll be back on here.
Please be careful on your way up... Its supposed to be crazy weather tonight and tomorrow morning...
Sky Hye is offline
post #4 of 10 Old 12-06-2007, 09:57 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Jerry always gets to leave the office for JeepForum meetings.
Meanwhile I'm stuck here doing all the work.
Wheelin98TJ is offline
post #5 of 10 Old 12-06-2007, 10:14 AM Thread Starter
Sky Hye
Sky Hye's Avatar
Yea, Some people Just have it nice... I'm just stuck here designing Jeep parts... Life just stinks eh??? hehe
Sky Hye is offline
post #6 of 10 Old 12-11-2007, 03:11 PM Thread Starter
Sky Hye
Sky Hye's Avatar
Ok. I cleaned the IAC, and even dismantled nd cleaned the entire Throttle body. I noticed my RPM's vary between 300-200 rpm. It drops really low when I put it into reverse or drive. Help...
Sky Hye is offline
post #7 of 10 Old 12-11-2007, 03:30 PM
Giviner
Giviner's Avatar
Did you clean the TPS (throttle position sensor)?
If not I would try that. If that doesn't work, you may need a new sensor.
2003 TJ Sahara
2010 WK
Giviner is offline
post #8 of 10 Old 12-11-2007, 03:38 PM
Jerry Bransford
Administrator
Unless later model TPS's are no longer sealed, they are sealed and cannot be cleaned. At least the TPS on my '97 was sealed and when mine went bad, I had to replace it.
post #9 of 10 Old 12-11-2007, 10:33 PM Thread Starter
Sky Hye
Sky Hye's Avatar
I sprayed everything else. I figured out the IAC is bad, because the second time I cleaned it, tonght, it failed to start unless I had the throttle open. I then dismantled it and tapped it around a bit and it began idling at 2000 rpm. I got it to where it idles at 1000. So now where can I get an IAC for cheap? Should I risk ebay or a jeep junk yard? are the ZJ and TJ IAC's the same?
Sky Hye is offline
post #10 of 10 Old 12-29-2007, 01:08 AM Thread Starter
Sky Hye
Sky Hye's Avatar
Ok,. latest update. I changed out the IAC. and a few days ago, I was pulling out to make a right turn and it stalled. I was so pissed. The idle also fluctuates, it sounds like a supercharged car's idle, up and down. also when backing up or going slowly with the wheels cranked, the engine revs up and down on its own.
Sky Hye is offline
Just Shuts Off coachparker44 YJ Wrangler Technical Forum 12 12-27-2009 07:33 PM
90' 4.2 shuts off on it's own montanamanone YJ Wrangler Technical Forum 1 09-11-2009 01:51 PM
91 yj shuts off rkg1275 YJ Wrangler Technical Forum 4 07-11-2006 12:12 PM
TJ starts up, doesnt idle right and shuts off? TXjeepTJ TJ Wrangler Technical Forum 6 02-20-2006 08:00 AM
Shuts off at stops, Slight rough idle... lostnwoodscj5 YJ Wrangler Technical Forum 1 05-04-2003 08:17 PM
