HELP -- My Front Driveshaft is Hitting the Transmission Crossmember!?!? - JeepForum.com
post #1 of 27 Old 06-11-2010, 12:41 AM Thread Starter
AZJeepNewbie
So I think I've tracked down this strange noise I sometimes get while wheeling in bigger rocks. Evidently my front driveshaft rubs on my crossmember when the axle is drooped. Here are some pics.
I've jacked up the front of the car by the driver's side frame rail to let the axle droop. You should be able to see where the driveshaft has been hitting the cross-member, and it's just about touching right now.
Closeup
Anybody know why this is happening, and how I should address it?
Build info is in my sig.
Thanks for any info!!
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #2 of 27 Old 06-11-2010, 12:49 AM
Red_
2016 KL Cherokee
Are you lifted? It shouldn't hit under normal circumstances
Red_ is offline
post #3 of 27 Old 06-11-2010, 12:50 AM Thread Starter
AZJeepNewbie
Lifted 3". Just installed it a couple of weeks ago.
post #4 of 27 Old 06-11-2010, 12:53 AM
bojang
Looks like a transmission skid plate mount to me. You can probably take it off till you find something better to replace it. Like the one from skid row or something.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
post #5 of 27 Old 06-11-2010, 01:02 AM Thread Starter
AZJeepNewbie
Yeah, you're right. It's just the skid plate mount. I guess I could grind it to add some clearance. But, I'm wondering why I haven't heard of folks having this problem before.
Thanks!
post #6 of 27 Old 06-11-2010, 03:43 AM
Boodyrider
Looks like a crappy design to me. My 97 has no issues, even with a tummy tuck. Of course, my engine/trans skid is nowhere near the driveshafty and doesn't cross frame rail to frame rail.
Anyways, yours hits due to the greater droop available with the lift.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #7 of 27 Old 06-11-2010, 04:05 AM
chmo
This is a common problem with lifted wranglers with auto tranny and OE tranny skid.
There is a write up in the net (link not at hand) of how to modify the crossmember for driveshaft clearance.
This crossmember is NOT carrying anything else besides the skid it self and of course should be strong enough not to bend if you put your Jeep on its belly .
So what the mod actually does is cutting the crossmember and welding in a reverse U which goes above the DS. Simple hack and weld job with the right measurements and some black rustoleum paint.
(If you can do it for cheaper than buying a skidrow tranny/engine skid which covers the oil pan as well and mounts to the OE transfer case skid )
cheers
chmo is offline
post #8 of 27 Old 06-11-2010, 04:42 AM
gregdean13
or for now you can just cut off that side, mine was like that for a while.
"not all those who wander are lost"
gregdean13 is offline
post #9 of 27 Old 06-11-2010, 04:59 AM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
Thanks!
That problem happens whenever you lift an auto(03-06) because of the skid up front on 03-06's.Simply take a sawsall or hack saw,cut half way through the crossmember directly under the driveshaft where it hits and 5" wide,then bend the piece back to keep the support on the skid.
TheBoogieman is offline
post #10 of 27 Old 06-11-2010, 05:50 AM
RubiconRazorbac
RubiconRazorbac's Avatar
X2. One more thing to think about when lifting a Jeep with the 42RLE.
If you're staying on the pavement, just take the "t-shaped" part that's hitting the driveshaft off. There's 1 bolt into the frame on each side and I think 2 holding that part onto the t-case skid. Just leave the t-case skid in place.
Mine is gone in anticipation of being replaced by the Savvy under armor
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #11 of 27 Old 06-11-2010, 06:58 AM
F9K9
F9K9's Avatar
Don't buy Rusty's tranny skid. You'll have the same problem. I just gave mine away after modifying it 4 times.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #12 of 27 Old 06-11-2010, 07:57 AM Thread Starter
AZJeepNewbie
Thanks, guys! I can't believe after two years of reading this forum, I never of this problem before. How come ya'll didn't say anything on my build thread, huh?
Time to get out the hacksaw and play with the welder. Oh, and I do have a message into Gerald about being a tester for their skid when it comes out for the Rubicon auto.
Thanks again!
post #13 of 27 Old 06-11-2010, 05:39 PM
F9K9
F9K9's Avatar
...........Oh, and I do have a message into Gerald about being a tester for their skid when it comes out for the Rubicon auto...........
Get back in line, kid!
F9K9 is offline
post #14 of 27 Old 06-11-2010, 06:11 PM
NorCalCon
I just cut the support at the skid and unbolted it at the frame. It's still pretty sturdy I ran plenty of hard trails with lots of rocks and never had a problem. Now Ive got a Full Traction Engine/Trans skid that bolts to their belly skid.
NorCalCon is offline
post #15 of 27 Old 06-11-2010, 06:41 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
drive shaft , front drive shaft , transmission cross member
lift installed, front DS hitting front crossmember need advice. kittyhawk TJ Wrangler Technical Forum 5 09-01-2007 09:43 PM
Front Driveshaft Rubbing On Left Crossmember, help! 0blcktj6 TJ Wrangler Technical Forum 20 04-23-2007 10:41 AM
front driveshaft hitting crossmember bloke279 TJ Wrangler Technical Forum 8 04-05-2007 11:05 AM
Front Driveshaft hitting Skid Redrub04 TJ Wrangler Technical Forum 9 03-27-2007 12:20 PM
Front Driveshaft hitting Skid Plate Crossmember JFiorentino TJ Wrangler Technical Forum 12 05-02-2005 09:27 AM
