#1 | |
43 Years with Jeeps
Help WITH MY DIFFERENTIALS
OK people my dealer says its time to change my diff fluids and wants $100. each. I think I can handle this myself but I need some advice on materials. Is 80W-90 gear lube correct, if so what brand? I've got 2 bottles of limited slip additive to put in each diff. Does the front and rear use the same materials? Even though I'm a long time Jeep owner, this 05 Rubicon is new territory.
THANKS
#2 |
Jeep
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#3 |
Do it right or not at all
![]() Join Date: Jan 2003
Your Rubicon does not have the type of limited slip differential in the rear that requires any type of limited slip additive, you can return those two bottles of additive for a refund. 80W-90 is fine, I would just go with a major brand of synthetic gear lube like Valvoline, Mobil-1, etc.. Besides, all of those already contain the limited slip additive which while not needed by either of your Rubicon's axles, won't hurt in the least.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#4 |
43 Years with Jeeps
OK GUYS
I think I have the mechanics part down pat. Why would my service manual say to use a additive if it doesn't need it. I also though that the rear was a air locker and a limited slip. Please clarify. ![]() |
#5 | |
#6 |
43 Years with Jeeps
Thanks for the info Jerry. As for RTV, Jeep says to use the GRAY and I've always used BLUE. Does it matter?
THANKS |
#7 | |
#8 |
Lifted/Locked/Rolled/Sunk
DC specifies 75W-140 synthetic for the Rubicon axles... limited slip additive not needed.
I need a 35" tire for spare. PM me if you have something. My Hummer Hole video SIRA 4x4 club I'll be Savvy someday!
#9 | |
#10 |
Give some consideration to Lube Lockers, They cost but are well worth it in my opinion.
#11 | |
Pics... [URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL] TJ Stretch Thread... [URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL] |
#12 |
Wow, well I guess i'll keep my silly mouth shut since that appears to be the definative word on Lube Lockers.
#13 |
I just pulled my rear cover last night & re-RTV'd it because it was leaking... it's a touch awkward holding the cover up there without smearing the RTV all over until you can get a couple bolts in... but it's not worth the cost of a Lube Locker even if it did seal as well.
#14 |
What's wrong with just using a gasket? Seems alot easier and more reliable to me. I am gonna change my diff oil in a week, never done it before. thanks for the web link of step by step instructions.
#15 |
I have two comments.
1. If you have a Rubi, you need 75W140 for the rear diff (helical LSD) 2. If you have a Rubi, you don't need to pull the covers and mess with gaskets / RTV / etc. (they have drain plugs) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
