Help with my D44 axles!!! - JeepForum.com
post #1 of 9 Old 08-05-2010, 09:39 AM Thread Starter
kcchapman
I got a D44 out of a Rubi to put in my tj, the only problem is I don't know which axle goes in which side, as the axles were not in when I got it. PLEASE HELP!!!
You're in charge of two things around here, Jack and Sh-t and Jack just left town
kcchapman is offline
post #2 of 9 Old 08-05-2010, 09:51 AM
breckboarder55
If I understand you correctly... The one with the differential centered goes in the rear. The one with the offset differentials, and knuckles set up for steering goes in the front...
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #3 of 9 Old 08-05-2010, 09:52 AM
WillysEdition04
RH side: 29 3/4"
LH side: 29 1/4"
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #4 of 9 Old 08-05-2010, 10:00 AM Thread Starter
kcchapman
By lh do you mean drivers side?
post #5 of 9 Old 08-05-2010, 10:05 AM
WillysEdition04
Yes.
08 JK Unlimited
post #6 of 9 Old 08-05-2010, 10:06 AM
WillysEdition04
Give the guy a little credit!
08 JK Unlimited
post #7 of 9 Old 08-05-2010, 10:15 AM Thread Starter
kcchapman
thanks to both of you, both have more knowledge than i do!
post #8 of 9 Old 08-05-2010, 11:24 AM
vector6
i lol'ed...
vector6 is offline
post #9 of 9 Old 08-05-2010, 12:37 PM
breckboarder55
I wasn't trying to be rude, but I seriously thought that was his question...
Maybe I'm the clueless one?
01 Honda S2000DD
d44 , dana 44 , axle , install , tj , wrangler , shaft
Dodge axles VS Ford Axles???? Allen52105 YJ Wrangler Technical Forum 7 08-07-2009 02:23 PM
Swapped axles- No ABS on new axles????? suprman4real YJ Wrangler Technical Forum 2 05-11-2009 08:52 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 11:10 AM
New JK Axles/Mopar Performance Axles Badcbr TJ Wrangler Technical Forum 8 08-21-2007 05:36 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 01:40 AM
