I run a plow on my 1997 TJ and the power lead for the plow controller has been connected to the Coolant Fan lead located in the Power Distribution Center (fuse box) under the hood.
I somehow shorted out the connection and now there is no power to the lead (you have to remove the relay (#G)) to get access to the power lead.
Is there a reset to get power back to this relay? The relay itself is not blown...you have to remove the relay and plug your plow controller lead into the open slot beneath the relay.
Thanks in advance.
Thanks in advance.
