help me find fluid leak and smoking problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > help me find fluid leak and smoking problem
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 08-17-2015, 06:05 PM   #1
JeepJeepImABeep
Jeep smokes gray smoke from engine compartment very badly after running for a while and turning her off. Smells like some kind of burnt oil, not sweet and not coolant. I am losing power steering fluid like mad but the wet spots from the power steering fluid are not near where the smoke is coming from, smoke is coming from around one of the oxygen sensors. I did have an oxygen sensor error code a few weeks ago which I cleared and ignored but doesn't make sense that it is causing the smoke.
Here's the oxygen sensor in question, where the smoke comes from:
A better look at it:
You can see power steering fluid drip (I think) on my driver front tire:
[/url]
But the oil pan looks pretty wet too:
Same with the side of the engine, pretty wet looking:
The transmission looks wet too though:
I think this thing under the front is also dripping power steering fluid:
JeepJeepImABeep is offline   Reply With Quote Quick reply to this message
Unread 08-18-2015, 02:42 PM   #2
JeepJeepImABeep
It only seems to smoke when I've been driving it around a bit, and also it's not overheating and not coolant.
Unread 08-18-2015, 03:26 PM   #3
Fozz625
Did you check your power steering hoses while someone turned your steering full lock and held pressure? The hoses are prone to pin holes that don't show up unless the pressure is built up from turning.
Fozz625 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2015, 07:40 PM   #4
JeepJeepImABeep
Where can I find those and also would that explain the smoke coming from around the oxygen sensor area?
Unread 08-18-2015, 08:38 PM   #5
Fozz625
Just follow the hoses from the power steering pump. If there is a hole it will be very obvious. I would have a fire extinguisher on hand. If the fluid hits the exhaust manifold it could flash.
Edited to remove extra word.
Unread 08-18-2015, 08:46 PM   #6
Fozz625
And yes that could explain the fluid you seeing as,well as the smoke and burning smell. I would not drive the Jeep until I found and repaired the problem. It would be a shame to burn your vehicle to the ground.
Unread 08-18-2015, 10:46 PM   #7
JeepJeepImABeep
Thanks I'll check that tomorrow morning... the power steering pump is attached to where I put power steering fluid in, right?
Unread 08-19-2015, 06:55 AM   #8
DoomsdayTJ
Yes, it is driven by the belt and is attached to where you put the fluid in.
DoomsdayTJ is offline   Reply With Quote Quick reply to this message
Unread 08-20-2015, 10:58 AM   #9
JeepJeepImABeep
I checked the two hoses that come from the bottom of the power steering pump. I can't find any holes in them and the hoses themselves aren't wet, but the big metal thing they plug into at the bottom front of the jeep is all wet. Still at a loss though, because that is not anywhere near the oxygen sensor where the smoke is coming from.
Unread 08-20-2015, 11:13 AM   #10
biffgnar
biffgnar's Avatar
Fluids from anywhere up front can get blown back onto the exhaust and smoke. Don't get to fixated with where the smoke is coming from.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 08-20-2015, 12:23 PM   #11
Jeepsr4me
That oil pan is about to BLOW..... rust thru....
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 08-20-2015, 01:01 PM   #12
Partsmke
Oil on your tire seems to be gear oil coming past the inner axle seal. Are you having a "blow-by" issue? What does the air filter look like? I'm assuming that it is connected to the valve cover.
Partsmke is offline   Reply With Quote Quick reply to this message
Unread 08-20-2015, 04:04 PM   #13
JeepJeepImABeep
Well it's just weird that it's coming from around the oxygen sensor, and I had the oxygen sensor code on the check engine light. Also, I'm noticing the jeep is stalling out and has a rough idle (also oxygen sensor?)
Maybe I should replace the O2 sensor anyway. But I'm not sure which one to get. Can you tell from the picture if it's upstream or downstream?
Unread 08-20-2015, 04:05 PM   #14
JeepJeepImABeep
I will take a look at the air filter and let you know.
Unread 08-20-2015, 04:11 PM   #15
JeepJeepImABeep
I tried taking the picture of the smoke after I took the jeep around the block from a cold start, literally less than 1 minute of driving. But it doesn't really show up in the picture. If I drive it a bit more the smoke will really come out.
