help. locking torx screw? - JeepForum.com
post #1 of 42 Old 08-27-2013, 10:31 AM Thread Starter
TJJeepJosh
Bought an or fab bolt in roll cage and began installing it. but when I got got to the 2 bolts holding the stock roll bars next to the b pillar there are these almost like locking torx screws. looks like a normal t50 head but it has a pin in the middle. is there a special piece I need to undo these?
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 42 Old 08-27-2013, 10:33 AM
FleshEater
2014 JK Wrangler
I believe it's a security torx bit. They have indentations in the center of them.
http://www.summitracing.com/parts/wmr-w1367/overview/
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #3 of 42 Old 08-27-2013, 11:44 AM Thread Starter
TJJeepJosh
ya that looks just like it thanks
post #4 of 42 Old 08-27-2013, 12:05 PM
Ben
big f'n pipe wrench.
Ben is offline
post #5 of 42 Old 08-27-2013, 12:11 PM
matthew900
matthew900's Avatar
Autozone has a set if security torx wrenches if you're looking to get something fast today so you can continue with the project.
matthew900 is offline
post #6 of 42 Old 08-27-2013, 12:16 PM
FleshEater
2014 JK Wrangler
That's asking to strip it out. 1/2" drive should suffice if 3/8" can't get it.
post #7 of 42 Old 08-27-2013, 12:29 PM
Ben
You must not know what a pipe wrench is.
Ben is offline
post #8 of 42 Old 08-27-2013, 12:34 PM
thirdeye
i dont see how a pipe wrench would help with a security torx bolt
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #9 of 42 Old 08-27-2013, 12:36 PM
CrawlingForward
Use an angle grinder to flatten opposite sides, then use an open wrench.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #10 of 42 Old 08-27-2013, 12:37 PM
Ben
You put it on there, and turn the security torx bolt out.
When I did cage work on mine, all those torx & security torx in the cage were frozen.
I broke a bunch of torx bits, and was at my wits end when I grabbed a big pipe wrench.
It worked like a charm, and I wish I had started with it.
Especially for the guy that says it'll strip it, nope, it's grabbing the outside of the bolt.
If you can get the bolt to start turning with a pipe wrench, then you still have factory minty fresh torx internal to use to turn it the rest of the way out.
The heads of the security torx on the A-B spreader stick out proud of the tube, there's plenty of room to get a pipe wrench on there, and if it didn't work I wouldn't say anything.
Ben is offline
post #11 of 42 Old 08-27-2013, 12:39 PM
FleshEater
2014 JK Wrangler
Yes, I do. And most hillbillies I know clamp these onto ratchets or wrenches.
I don't see what's so hard about using a ratchet and socket.
post #12 of 42 Old 08-27-2013, 12:42 PM
FleshEater
2014 JK Wrangler
I see where you're headed with the pipe wrench.
Air tools are better.
post #13 of 42 Old 08-27-2013, 11:06 PM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
I also used a big f'n pipe wrench for those f'n security bolts when I installed my Or-Fab cage.
TJDaveX is offline
post #14 of 42 Old 08-28-2013, 06:17 AM
2jhanna
Vise grips worked for me. Then replaced with grade 8 hex heads.
I have read where some were able to break the little "titt" out of the center, I tried with a center punch but it just laid over.
jhanna
denton county, tx
2jhanna is offline
post #15 of 42 Old 08-28-2013, 06:40 AM
88hatchy
You won't have a problem if you use quality tools. At the very least, you should get a set of GearWrench tamperproof torx bits.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
confused , help needed , roll cage , torx
