help with a lift - JeepForum.com
post #1 of 5 Old 07-06-2010, 01:14 PM Thread Starter
lifebestwitjeep
help with a lift
I have a 4 lift from rough country. after installing the lift on the front i saw the new spring was against the rubber piece in the middle. I made sure when installing the lower control arms that cam bolts were exsactly where they were before. I need help. I have no idea how to fix it.
lifebestwitjeep is offline
post #2 of 5 Old 07-06-2010, 01:47 PM
cstevens
pics?...
Chris
W3HAP
cstevens is offline
post #3 of 5 Old 07-07-2010, 08:04 AM
DoGood
that rubber piece in the middle of the spring is the bump stops. Since you have lifted the jeep the fixed length trackbar causes the axel to shift to the driver side of the jeep. Typically it's not really an issue, but can be remedied with an adjustable front trackbar.
^I wouldn't listen to what I say. I don't know what I'm talking about. Please use the search feature.
DoGood is offline
post #4 of 5 Old 07-07-2010, 08:08 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #5 of 5 Old 07-09-2010, 02:23 PM Thread Starter
lifebestwitjeep
i have the adjustable track bar. Now that i finished the lift i couldnt help but drive and the bump stop has backed off the spring by an 1/8in.
rc lift kit , rough country
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 09:11 AM
Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) Ludoc TJ Wrangler Technical Forum 7 03-31-2005 10:03 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
