Help installing KC hilites switch - JeepForum.com
post #1 of 11 Old 07-27-2008, 09:18 PM Thread Starter
xdfhdfjn
I have just installed KC Hilites on my bumper and am stuck on installing the switch. I'm tyring to use the knock out panels that are under the temperature controls in the middle portion of the dash board to mount the switch. My problem is that i cannot access it from under the steering column.
What i really need to know is how to remove the entire black portion that surrounds the stereo/ temp controls/ knockout panels so i can run the wiring . I am trying to keep this installation as clean and professional looking as possible so the more detailed the advice the better.
Thanks!
xdfhdfjn is offline
post #2 of 11 Old 07-27-2008, 09:24 PM
mdawg4x4
2017 JK Wrangler
Start with the long piece the defroster blows through on top of the dash. It just pops out. Then two screws under that piece in the middle and another behind the ashtray and the center piece should pop out pulling the the top 1st. Excessive force always breaks something.
98 TJ Sport, 2017 JKU Rubicon
mdawg4x4 is offline
post #3 of 11 Old 07-27-2008, 09:30 PM
cmb516
yea just did this the other day pop the top defrost vent off then unscrew the two screws at the top then pop the ashtray out and unscrew the screw there, pull the plate off from the top first then unscrew the 4 screws around the panel with the cigarette lighter and the three button panels, then pop the fake switch out and put the good switch in then wire it up and screw everything back in its very easy
cmb516 is offline
post #4 of 11 Old 07-27-2008, 09:41 PM
dabrogger
X2 on the removal. i just did mine too. only difference was that i wasnt able to just "pop" out the false switch thing and put the kc one in; i had to pop it out, drill a hole in it and dremel the sides down and put the switch in there. it looks pretty good and if or when i want to do something different, i just need to get another switch blank and put it back in.
dabrogger is offline
post #5 of 11 Old 07-27-2008, 09:48 PM
mdawg4x4
2017 JK Wrangler
Got a finished pic?
mdawg4x4 is offline
post #6 of 11 Old 07-27-2008, 10:25 PM
Garth Thomas
Did you replace the original lights on the bumper? If so why not use the original switch, just have it power the relay that came with the new lights.
Garth Thomas is offline
post #7 of 11 Old 07-27-2008, 10:45 PM
02tjsport
2014 KL Cherokee
Fogs on the newer TJs are on the column with the headlight switch. A tad harder to get to.
Also on newer TJs (his 05). He doesnt have an Ash tray. Im not sure how to get that last screw out on those. Maybe they dont have a screw down there.
be careful when drilling a hole in the blank plastic piece that you are going for. They can catch on the drill bit and snap pretty easily
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline
post #8 of 11 Old 07-28-2008, 05:51 AM Thread Starter
xdfhdfjn
Yep, no ashtray here. I am going to try tonight on this.
xdfhdfjn is offline
post #9 of 11 Old 07-28-2008, 06:21 AM
scdiver2001
Do they make switches to go where the fake ones are instead or drilling and using a dremel?
scdiver2001 is offline
post #10 of 11 Old 07-28-2008, 08:50 AM
02tjsport
2014 KL Cherokee
yup...contura style switches.
www.otrattw.com
Great product, great customer service.
post #11 of 11 Old 07-28-2008, 04:00 PM
jake1977
www.otrattw.com
I agree that is the route I went. I bought the Kc Hilites also. First thing to go was their switch and bought a contura II from otrattw. Fits great in the switch bezel.
jake1977 is offline
Installing rocker switch.... hmartinez JK Wrangler Technical Forum 37 11-21-2010 06:36 PM
Help installing an Air condition bypass switch.. jeeps4life TJ Wrangler Technical Forum 5 01-23-2010 03:19 PM
Installing an airbag cutoff switch in my 03 flyenryan TJ Wrangler Technical Forum 15 01-18-2010 03:28 PM
Installing ignition rocker switch wesley75 YJ Wrangler Technical Forum 10 08-17-2008 09:23 PM
Installing Fog Light Switch psubully TJ Wrangler Technical Forum 5 05-25-2004 08:47 PM
