Help I identify these bolts - JeepForum.com
post #1 of 18 Old 06-21-2011, 09:34 AM Thread Starter
TheSlowDown
Does anyone know where these bolts belong in a 2005 TJ?
I stripped the interior of my Jeep to apply Monstaliner and foolishly labeled the bolts below as "rear interior."
I put most everything back together and am drawing a blank on these shiny important looking bolts. Thanks for the help!
TheSlowDown is offline
post #2 of 18 Old 06-21-2011, 09:35 AM
jeepinhokie
seat belt? are they T55 size?
HOKIES UNITED!
jeepinhokie is offline
post #3 of 18 Old 06-21-2011, 09:41 AM Thread Starter
TheSlowDown
Thanks for responding. I have the seat belt retractor box bolts in already... black color - both front and rear... I also have the seat buckle holder in as well in the middle of the floor in the back.
The bolts are T55.
post #4 of 18 Old 06-21-2011, 09:45 AM
jeepinhokie
i just looked at my 04, they are the for the other end of the seat belts. where the seat belt bracket bolts to the tub below the rear retractor. the bracket on the seatbelt is the same metal.
HOKIES UNITED!
post #5 of 18 Old 06-21-2011, 09:46 AM
Boodyrider
I think they are for the 'rear interior'.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #6 of 18 Old 06-21-2011, 09:54 AM
jeepinhokie
I can text you a picture if you would like. dont have the ability to take and upload pictures currently. PM me your number.
HOKIES UNITED!
post #7 of 18 Old 06-21-2011, 09:57 AM
Smeg
They are now "spares" in case you need them later. Over the years I have accumulated lots of "spare" hardware...
'06 TJ Yellow nothing special
'15 WK2 Limited Deep Cherry Red Wrecked
'12 WK2 Laredo Black Wrecked
Smeg is offline
post #8 of 18 Old 06-21-2011, 10:00 AM Thread Starter
TheSlowDown
PM sent thanks.
post #9 of 18 Old 06-21-2011, 10:01 AM
CrawlingForward
X2 on Seatbelts. Check to make sure your all the ones you put your seatbelts back in with don't belong elsewhere.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #10 of 18 Old 06-21-2011, 10:06 AM
jeepinhokie
Originally Posted by TheSlowDown View Post
PM sent thanks.
in the picture i sent is of the passenger rear, the bolt you are describing is the bottom most bolt. it helps forms the lap belt when you pull the buckle across you chest to buckle in.
HOKIES UNITED!
post #11 of 18 Old 06-21-2011, 10:12 AM
Hailchief
They look to me like the bolts that hold the top on. Check all of your bolts in your top.
CHIEF
Hailchief is offline
post #12 of 18 Old 06-21-2011, 10:16 AM
jeepinhokie
CHIEF
negative ghostrider, the pattern is full.
HOKIES UNITED!
post #13 of 18 Old 06-21-2011, 10:17 AM
chubbena
perhaps you have the hard top bolts on the seatbelt retractor box
chubbena is offline
post #14 of 18 Old 06-21-2011, 10:18 AM Thread Starter
TheSlowDown
Got it. Now... just to get the seat belts some slack from the retractor so I can actually bolt them down to the floor.
post #15 of 18 Old 06-21-2011, 10:19 AM
pdangerp
pdangerp's Avatar
Those look like the bolts that hold the ends of the seat belt in the rear to the side of the tub.
pdangerp is offline
Adding bolts to 16.5 inch humvee wheels(8 bolts to 16) KJFactor YJ Wrangler Technical Forum 7 08-22-2010 08:16 AM
Want to replace stock control arm bolts with grade 8 bolts... Mino TJ Wrangler Technical Forum 7 01-23-2010 10:02 AM
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
Tool for taking off hardtop bolts and windshield hinge bolts TheDiabetic TJ Wrangler Technical Forum 10 03-30-2006 05:49 PM
Removal of snapped body mount bolts and bolts in general? SpedJeep YJ Wrangler Technical Forum 15 10-16-2005 09:01 PM
