Help I broke Something! Plastic Elbow, Pics Included
#1 | |
Okay, I am replacing my exhaust manifold today and tomorrow. Everything went pretty smooth except for this plastic elbow thingy. I went to pull the hose off of it and it snapped right off. I then tried to pry the stupid thing off and it keeps breaking. Is there a trick?
[FONT=Comic Sans MS]1998 Jeep Wrangler Sport [/FONT] [FONT=Arial Black]You know what they say, "everywhere you go there you are."[/FONT] |
#2 |
I think that is your PCV valve, not 100% sure but it would make sense.
Who lives in a pineapple under the sea? "Horrendously scratched black jeep club member #7"
(w/ Hurculined accents) |
#3 |
Just break it the rest of the way out.......
I did the same thing. It costs about 6 bucks at a dealer. There is a trick to putting it back in. Fit the rubber grommet in the valve cover first then push the elbow into the rubber grommet. |
#4 |
just get a knife and pry it out. i broke one too. it's easier to unplug it from the other end of that hose, than it is to get it off that valve cover.
'02 TJ X Apex Edition '00 XJ Sport |
#5 |
Hay thanks for the replies. I will break the thing out in pcs. Is it easier to pry from underneath the rubber boot?
#6 |
lol I did the same thing just last week. Dealer should have my part in soon. lol
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7 |
#7 |
Are you in SW FL? I have one...
'97 TJ Sport, 4.0L, AX-15, D30/35, Dayton Timberline AT 31x10.5x15s, Warrior rack, Silverstars, KC HiLites Replacement Fogs, Optima Yellow Top, EBC Greenstuff pads and Centric rotors, 164K '97 Rodeo, '96 Jetta, '02 Cabrio, '03 E46 |
#8 | |
Never Forget
make sure those random pieces you break dont fall into the valve cover, could mess something up
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
#9 |
yep... definately the pcv valve... it's an easy fix... No need to pay 6 dollars to the dealer though... you can get one at autozone for about 3... all it really is, is a check valve.
#10 |
I went to Advanced Auto Parts and they were not able to get one. I was just about to head on over the AutoZone but didn't. I went to the dealer, pre paid my 6 bucks, and the part is supposed to be there tomorrow. I had to go to work, so I will wrap this up tomorrow.
Does anyone know of a majical tool to get the rest of the stupid out with? I am sure small pcs are falling inside my valve cover. Thanks for the help everyone. ![]()
#11 |
That is actually just called the "Fixed Oriface Fitting" it is part of the 4.0L Closed Crankcase Ventilation (CCV) System. The 4.0L engine does not actually contain a PCV Valve... only 4 cyl. Wranglers do. It accomplishes close to the same thing, but is just 1 less thing to actually worry about.
2004 TJ Sport 4.0L 5-Speed Patriot Blue 31x10.5r15 BFGoodrich All-Terrains Dana 30/44 3.73 Borla Cat-Back |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
