Help Help Help Problem With Front Shaft - JeepForum.com
post #1 of 6 Old 12-06-2006, 08:15 AM Thread Starter
imoafa
GUYS,
please help me to solve this problem...
after the rainy days in saudi, i noticed a squeecing sound (weet weet weet weet) from the front drive shaft. i tried whatever to fix the problem but i could not.
i used the WD40 but did not work.
it comes and goes as it likes and it does not stop at a certaine speed, justr when it does want to show its not there.
i thought its from the U joint but i am not sure yet since no vibration is attended.
guys,
if anyone had the same problem before please advice for the solution cuz i believe the full drive shaft is so expensive and i am not willing to open the transfer case to change the bearing...
Ibraheem..........
imoafa is offline
post #2 of 6 Old 12-06-2006, 08:31 AM
dr hook
try going to google and typing in "angry sparrows"
Lifted ZJ with stuff.
dr hook is offline
post #3 of 6 Old 12-06-2006, 10:23 AM
jeeptj19992001
Go To Stu's Site,
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #4 of 6 Old 12-06-2006, 10:43 AM
FLATFENDER54
FLATFENDER54's Avatar
maybe your ball centering kit is the problem (making the angry sparrow sound)
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #5 of 6 Old 12-06-2006, 10:46 AM
tommaho
tommaho's Avatar
Here is Stu's site:
http://stu-offroad.com/
You'll need to register, but go to the axles section and check out the driveshaft overhaul articles.
To verify, you can just pull the front driveshaft and see if the sound goes away. If it's bad, keep it out until you fix it to save yourself the aggrivation and expense of a siezed joint.
The parts here in the states are about $60 and a cheap u-joint press can be had for under $50.
Tom
tommaho is offline
post #6 of 6 Old 12-06-2006, 12:42 PM
BlueFlame
BlueFlame's Avatar
In rains in Saudi?
BlueFlame is offline
No front d-shaft-no problem...w/ d-shaft-death wobble and can't get to 50mph...help gadawgz71 TJ Wrangler Technical Forum 5 08-06-2008 03:12 PM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 09:34 AM
Front Drive Shaft Problem with one piece axle upgrade Bob_R YJ Wrangler Technical Forum 5 08-05-2007 07:03 PM
front axle shaft u-joint problem 91GTA350 YJ Wrangler Technical Forum 7 09-27-2005 09:46 AM
Anyone have a front d-shaft/exhaust pipe rub problem? Ex CCS Racer YJ Wrangler Technical Forum 2 11-07-2003 03:08 PM
