Quantcast HELP! Hard top leaking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > HELP! Hard top leaking
Old 03-02-2007, 05:18 PM   #1
texasjeep07
Sorry if this is a repost but the search is down. I have a 99 sport with the hardtop and evertime it rains water runs down between my top and door. The door seals are not in bad shape so I have no idea why it is leaking so bad. Luckily I have Husky floor liners so my carpet is not getting wet.
thanks
texasjeep07 is offline   Reply With Quote
Old 03-02-2007, 06:05 PM   #2
99TJSport
Are the rubber seals that go on the back of the dooropening between the top and the body in place? If not you can get leakage in that area.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline   Reply With Quote
Old 03-02-2007, 06:57 PM   #3
texasjeep07
yes those are in the right place. the leak is coming from the top of the door and the water runs down between the door and the windshield
Old 03-02-2007, 07:47 PM   #4
raven4640
mine does the same on the passenger side, which would be your drivers side as mines a uk right hand drive, i think it runs down behind that plastic trim thing thats held on with a few screws, post on here a while back said to fill them with slicone and that will stop the leaks.
raven4640 is offline   Reply With Quote
Old 03-02-2007, 07:58 PM   #5
texasjeep07
thanks ill try that and see if it works
Glock Forum
