Quantcast HELP with fuel line specs to convert to Fuel Cell?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > HELP with fuel line specs to convert to Fuel Cell??
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 06-05-2006, 01:52 PM   #1
HootenTJ
I have a '97 Jeep Wrangler SE and am in the process of taking out my stock gas tank and switching to a Summit Racing Fuel Cell that fits behind the rear seat. It's a 15 gallon tank and it says it comes with -8 AN outlet and return fitting size. I called the Jeep dealer and the guy said he thinks the fuel line I have now is a 3/8 in size, he didn't seems too sure though. Does anyone know what size my stock fuel line is and what is needed to convert it? Will I need new fuel lines? And will I need an aftermarket fuel gauge or will the GM style(0-90 ohms) work with my stock Jeep fuel gauge? Thanks for all help y'all...
'97 4-Banger, 2.5L, 2" BBL, 4.10 gearing, 33x12.5 ProComp MTs, Custom Flat Fenders, Custom Front Bumper, 2-12" MTX Subs
HootenTJ is offline   Reply With Quote
Old 06-05-2006, 03:44 PM   #2
HootenTJ
And will my stock fuel lines work with -8 AN or -6 AN fittings??
Old 01-26-2010, 07:53 PM   #3
97casteeltj
bringing this one back from the dead...
i'm wanting to install a fuel cell using stock components, what are some of the better choices and ways to do it?
needing a new rig....
97casteeltj is offline   Reply With Quote
Old 01-26-2010, 09:35 PM   #4
mudmonkey2400
This is one way to do it:
Install a fuel cell in a late model TJ - Pirate4x4.Com Bulletin Board
I thought about doing this for awhile, but decided against it. One of the TJ's biggest negatives is it's lack of storage room inside. So there goes more of your storage. One of the TJ's best features is it's great departure angle. So you'd be improving something that- IMO, does not need a whole lot of improving.
You'll also get fumes inside the cab if you do not vent it right, it raises your COG, and costs as much as an aftermarket gas tank skid.
Unless you plan on stretching the wheel base, I wouldn't fool with it. Just my opinion though.
2000 TJ : RK 5.5" X-Factor Long Arm, 1.25"BL/MML, RE Monotubes, RK HD Steering, Warn M8000, Lock-Right D30, Detroit D44 w/4.88's, 35x12.50R15 Pitbull Rocker Radials
1990 MJ : 2.5L, 5spd, 2wd, short bed and bone stock.
mudmonkey2400 is offline   Reply With Quote
Old 01-26-2010, 10:56 PM   #5
Longoddr1
The hard fuel line is 3/8 inch and Russell Automotive makes a -6an to hard line adapter. I have used these before. They are made of aluminum and anodized. They have different styles depending on if the tube has the normal push on fitting or you need to use it on a standard round tube. They can also be male style if the tube is the female style(ford). Here is the part number of the style I use 640940
Hope this helps.
Longoddr1 is offline   Reply With Quote
Old 01-27-2010, 02:55 AM   #6
97casteeltj
it will be stretched and backhalved
Hope this helps.
thanks for the great info
Old 02-24-2010, 09:24 PM   #7
NalinMFG
www.NalinMFG.com
NalinMFG's Avatar
http://fullcirclefab.net/rci_research.html
just put together a list of (IMO) the most helpful TJ RCI installs out there, hopefully a few of those will assist in answering any other issues you might have
Proudly Serving: 13B Field Artillery 1-163rd
NalinMFG.com
5.25" TJ Speaker Adapters
http://www.facebook.com/nalinmfg Like for a 10% Coupon Code
NalinMFG is offline   Reply With Quote
Old 04-14-2010, 06:58 PM   #8
PDK
That site is down. Is there any chance u could re-post the info here? Thanks.
PDK is offline   Reply With Quote
Glock Forum
