post #1 of Old 08-20-2006, 01:42 PM Thread Starter
Existence
Help, error code 300
Every once in a while I get the "check engine" light during a long trip or wheeling, it normally goes away after a few days.
I got it today again, did the whole diagnostics thing and it came up with 2 error codes:
300: Misfire detected in multiple cylinders, and
304: Misfire detected in cylinder #4
What could cause these misfires? Is it a major concern?
There are two types of pedestrians, the quick and the dead.
Existence is offline
post #2 of Old 08-20-2006, 01:48 PM
ocezam
ocezam's Avatar
I had the same problem for over a year while I was running 32" tires with 3:07 gears. The problem hasn't re-occurred since I regeared.
I think constantly lugging the engine fouled the plugs.
My .02
'01 TJ. 4"Full Traction. 1" BL/MML. 35" BFG Muds. ARB's front & Rear. Full skids. Warn Winch. Lots of other crap!
ocezam is offline
4 cyl. TJ with code error 11 , please help ! kyhunter TJ Wrangler Technical Forum 10 07-28-2011 06:05 PM
What exactly does error code 55 mean? (completion of fault code display on the CEL) Tkahne88 TJ Wrangler Technical Forum 3 11-04-2009 08:46 AM
Error Code 25 BringThaPain TJ Wrangler Technical Forum 4 12-01-2008 08:57 PM
Error code help nettak TJ Wrangler Technical Forum 6 01-30-2008 09:57 PM
Error Code hop2465 TJ Wrangler Technical Forum 5 03-29-2006 07:49 AM
You may not post new threads
You may not post replies
