Help, emissions readiness monitors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Help, emissions readiness monitors
RIGID LED Light Blowout Sale - All Sizes, All Series, all USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Metalcloak: Celebrate Freedom with Free Shipping
Unread 01-12-2015, 05:59 PM   #1
bthompson12994
Alright, I've been on here a while but haven't said or done much, I need help though. It's time for an inspection and my emissions readiness monitors aren't ready. I understand the gist of what they are, but they won't ready. I've put about 400 miles on it since it was last worked on. I've used my code reader after driving for a while and certain ones will be ready, but when I cut the Jeep off and restart it, the four of them aren't ready again. On top of all that, I'm trying to sell this Jeep as soon as possible. I think it might be the battery. It struggles to start when cold, so I figure the battery might not have the voltage it needs and the computer basically resets every time the Jeep is off. The guy at Advance (not necessarily a guru) said he knows of chryslers in particular having computer issues. I haven't heard anything about this being tied to a computer issue before, but maybe I'm wrong. Any help is great, thanks.
It's a 2004 Jeep Wrangler Rubicon with an automatic transmission, lift kit and all that cool stuff.
bthompson12994 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 06:03 PM   #2
biffgnar
biffgnar's Avatar
Clean your battery terminals and cable ends until they shine. Then when you put it back together make sure the connections are very tight. It sounds like you are losing battery feed when it sits and that's resetting emissions monitors. It also means when you try to start you have a weak connection and so the starter struggles to pull enough power.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 06:13 PM   #3
bthompson12994
Thank you, that makes sense. I'll try it in the morning.
Unread 01-12-2015, 09:20 PM   #4
MJM1981
Also check your IOD fuse. Underhood FusBox
MJM1981 is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 07:13 PM   #5
bthompson12994
Battery terminals were the issue, once they were cleaned the monitors were ready within an hour and it was inspected. Thanks for all the help.
