Help! electrical problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Help! electrical problems
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFHELLA FF75 12V 55W H7 Fog Lamps - SPECIAL OVERSTOCK SALE F
Unread 02-10-2013, 09:20 AM   #1
NS2xTJ
Help! gauge problems
hey guys, i ve been searching for days on my own trying to find a thread to fix my problem without bothering everyone, but i cant seem to find one specific to my problem.
I have a 97' tj with a 2.5l with manual trans. my problem is that i have to turn the key multiple times(normally 2 times) to get my gauges to work; also i will be driving down the road and the speedo and tack will wall off. the other four gauges(fuel,volts,oil pressure,etc.) seem to stay on but i know the have also then quit working bc i have taken a decent size drive and the fuel gauge does not move.
I have taken the gauge cluster out and twisted th prongs 5 degrees and put dielctric grease on them like i found on one thread but that didnt work.
any help would be much appriciated
thanks nathan
NS2xTJ is offline   Reply With Quote Quick reply to this message
Unread 02-10-2013, 01:40 PM   #2
NS2xTJ
Anyone?
Unread 02-10-2013, 10:45 PM   #3
durango-bob
There is an issue with the connectors coming loose on the back of the cluster, but it sounds like you already took steps to fix this. Does hitting the top of the dash make the gages work? If so, you still have a connector issue.
durango-bob is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 06:41 AM   #4
Jim Guarino
I replaced the key switch to fix the same issue.
Jim Guarino is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 05:31 PM   #5
NS2xTJ
No hitting on the dash doesnt help i tried that too
Unread 02-11-2013, 05:32 PM   #6
NS2xTJ
thanks i was kinda thinkin that might have something to do with it but wasnt sure think ill give this a try is it hard to replace?
Unread 02-11-2013, 05:34 PM   #7
NS2xTJ
thanks for the help guys
Unread 06-25-2013, 07:54 AM   #8
HobieSun
Slight high jack here.
I too have a 97 Tj with the 2.5/auto.
My gauges wont turn on for about 5-10 minutes then they are fine. Bumps don't seem to do anything. I took it out but I don't see anywhere the dealer did anything. All the wires look factory. Pushed it back on while the jeep was running and the lights come on but no gauges.
Can someone explain where this twisting of the wires takes place? No luck on the fix yet.
HobieSun is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 10:28 AM   #9
HobieSun
I have tried just about everything with no luck. As soon as I shut the jeep off and turn it back on no gauges. Airbag light stays on constantly, with it running, all lights, no gauges at all. Bend the tabs, cleaned, wiggled every connection possible. Changed out the #17 fuse, nothing.
The ground strap on the top near the gauge connections has been messed with. Some Ahole cut the other end and used it for the radio I presume. I cleaned that up and touched it all over under the dash and didn't make any difference. Still no luck. Hitting it doesn't do anything.
There is a cable coming from the ignition to the shifter (auto). There is a little connector going to a round cylinder type thing that it plugs into . That gets pretty hot. Not sure what the heck that is. Other then that I don't notice anything else. Gauges will come on after about 5-10 minutes and stay on until I shut it off. Need some help.
Unread 06-25-2013, 12:37 PM   #10
HobieSun
Ok, now my speedo and tach will quit working while driving and everything else will work. I was messing with the key while driving and pulled it straight out. So that's not right. I cannot get it to mess up for me on demand. Does its own thing. Frustrated.
