Help!!! Dosen't Run - JeepForum.com
post #1 of 4 Old 11-07-2005, 02:56 PM Thread Starter
truckie453
truckie453's Avatar
Help!!! Dosen't Run
Hey all
Well I got up this morning and got into the jeep and she wouldn't start. She ticked and if I gave her gas as I turned the key she would run but the second I let off the gas she'd die... Any Ideas
Thanks in advance.
-truckie
Green Jeep #99
Firefighting Jeep #1
Sometimes the things that may or may not be true are the things a man needs to believe in the most. That people are basically good; that honor, courage, and virtue mean everything; that power and money mean nothing; that good always triumphs over evil, that true love never dies. Doesn't matter if it's true or not. You see, a man should believe in those things, because those are the things worth believing in.
truckie453 is offline
post #2 of 4 Old 11-07-2005, 03:41 PM
JSBlu974X4
could be a lot...wires, coil, distrib, throttle pos sensor, crank pos sensor..any codes?
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #3 of 4 Old 11-07-2005, 04:28 PM Thread Starter
truckie453
truckie453's Avatar
I don't have a code reader and it's a '99 so I cannot do the on-off-on thing... The thing ran fine earlier this morning (5am) but when I got in again at 8am it wouldn't stay running...
anyone else with an idea?
-truckie
Green Jeep #99
post #4 of 4 Old 11-07-2005, 04:34 PM
smoo26
this sounds like the problem I just had with my 99 have you had the battery checked, it turned out to be the problem with mine.
smoo26 is offline
Uconnect, Iphone G3, Worked now dosen't, No Dealer Help! consultJK JK Wrangler Technical Forum 13 06-16-2009 12:28 PM
my heater/ac blows or dosen't blow correctly polo196 TJ Wrangler Technical Forum 3 01-27-2009 09:52 AM
New Alt , New Battery , Jeep Dosen't Start. fataltherabbit YJ Wrangler Technical Forum 20 10-14-2008 03:51 PM
new lift.. dosen't seem to flex drew76924 TJ Wrangler Technical Forum 15 03-26-2008 05:56 PM
hvac system dosen't work?? drew76924 TJ Wrangler Technical Forum 3 10-30-2006 11:15 AM
