#1 | |
Help disk brakes
This is probably a really dumb question but here it goes, my disk brake pads are pretty hard against the rotors I took my wheels off and yup its the pads tight against the rotors, now this CANT be good for MPG and I cant figure out how to loosen the pads up, any help is greatly appreciated. Thanks.
#2 | |
Brake Wizard
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#3 |
Wrangler
the pads will always slghtly touch the rotors. if you look at the way a caliper is desiged..more specifically on a jeep which is a single piston caliper it sqeezes the two sides together, but there is no opposing force to pull them back apart. i don't think there is on any brake setup. they only way to loosen th pads is try pry against the pston wich will just push all the brake fluid back into your resivoir possiblt overflowing it but then again as soon as you step on your brakes again they will be touching...now if you are having trouble spinning the wheel becasue your pads as soo tight then you may have an issue. but in a nutshell sounds like your brakes are doing and looking how they should.
#4 |
Alright I was just not sure they were suposed to be gripping the rotor, thanks.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
