Help! Differential Hose. - JeepForum.com
post #1 of 13 Old 10-01-2010, 06:12 PM Thread Starter
ttugeorocker
I was flagged on the road today and told a hose was hanging from my jeep. It comes out of the front differential and I have no clue where the other end of it goes. I'm new to working on vehicles and need a little help with this one. The Haynes Manual didn't show this hose. Pics of the place where it comes out of the differential and what the loose end look like are posted on my picassa page:
Picasa Web Albums - OzJeep - Unknown Hose
Please help out a newb with little knowledge.
Thanks!
ttugeorocker is offline
post #2 of 13 Old 10-01-2010, 06:15 PM
vindicated
Did you miss me?
vindicated's Avatar
Can you click free the pics here please?
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline
post #3 of 13 Old 10-01-2010, 06:17 PM
CjinPA
CjinPA's Avatar
Its just a breather tube. I believe it gets held to the back of the grill with a clamp.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #4 of 13 Old 10-01-2010, 06:50 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The front axle breather hose goes here:
Attached to the upper radiator mounting bolt...
Knuckelhead is offline
post #5 of 13 Old 10-01-2010, 06:51 PM
2jhanna
just a vent hose, mine is routed up to the left (drivers) side of the radiator. should have a "plastic plug" attached to the end.
jhanna
denton county, tx
2jhanna is offline
post #6 of 13 Old 10-01-2010, 08:41 PM
wpparker
Yep the high the better if you like deep water
wpparker is offline
post #7 of 13 Old 10-01-2010, 09:09 PM Thread Starter
ttugeorocker
Thanks guys, I replaced the water pump and radiator recently. This guy must have been a casualty of that job. I'll get it straightened up tomorrow!
post #8 of 13 Old 04-21-2011, 08:31 PM
g4373
AAhhh.........Thanks for the pic.
g4373 is offline
post #9 of 13 Old 04-21-2011, 08:50 PM
Knuckelhead
AFSOC Retired
Glad to help and welcome to the forum.
G4373'S JEEP
User Has Not Filled Out Jeep Information.
Now fill in your profile...
post #10 of 13 Old 05-31-2014, 09:45 AM
jeepguy1122
Would that mess up my 4x4? And what if it doesn't connect at the radiator.
jeepguy1122 is offline
post #11 of 13 Old 05-31-2014, 09:53 AM
afusco1222
No it's just a tube to relieve pressure build up within the diff. You can relocate it to where ever you like, it does not have to go back to its original location.
afusco1222 is offline
post #12 of 13 Old 05-31-2014, 09:56 AM
GilaMtnJeep
GilaMtnJeep's Avatar
If it's not there the problem is water can get it and it doesn't necessarily have to be mounted at the radiator. It should be mounted high up, though. The purpose is to allow the differential to breath. Oil and air inside the case expand as the diff heats up and contract when it cools. If it's mounted too low or somewhere rain can get to it moisture can be introduced and cause major problems. That is how it can affect you.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #13 of 13 Old 05-31-2014, 07:42 PM
Knuckelhead
AFSOC Retired
No, but that's where the OEM put it and that's the position that would work best for you... HTH
2000 tj , front differential , help needed , hose
What is this hose going to no where from my front differential? BigOrange90YJ YJ Wrangler Technical Forum 7 09-14-2009 09:46 PM
hose to front differential bheiser TJ Wrangler Technical Forum 9 05-24-2009 10:40 PM
Front Differential Breather Hose jloehle TJ Wrangler Technical Forum 3 05-05-2008 02:33 PM
Where does the hose from the front differential connect? PABowhunter YJ Wrangler Technical Forum 9 06-24-2007 06:50 PM
Ooops...messed up a hose on my differential Lime Jeep TJ Wrangler Technical Forum 3 04-03-2006 05:08 PM
