Help! Clutch is making a horrible noise when depressed - JeepForum.com
post #1 of 9 Old 09-24-2008, 05:03 PM Thread Starter
Brandon97TJ
To start things off, a few months ago when I was sitting in my Jeep with my friend, we heard a strange noise when I was holding the clutch in. He said it sounded like my release bearing (or throw-out bearing) was going out. Like an idiot, I just put this potentially future problem aside.
Well yesterday when me and my friend we getting in my Jeep so I could take her home, I held down the clutch and cranked it, and this horrible screeching noise started going. When I let go of the clutch it stopped. So Now I figure my throw-out bearing went out.
I am trying to sell this Jeep so I can get a 4.0. Would it be possible for me to buy a new throw-out bearing and drop my transmission and get to my clutch and replace it with basic tools or will I need any special tools? How complicated of a procedure is this?
Thanks in advance for any advice.
Brandon97TJ is offline
post #2 of 9 Old 09-24-2008, 05:06 PM
justincue
a full socket set should be all you need.
justincue is offline
post #3 of 9 Old 09-24-2008, 05:08 PM
GilaMtnJeep
GilaMtnJeep's Avatar
If you're only going to replace the throw-out bearing then you don't need anything special as far as tools go. But, being how you have the tranny out, the best thing would be to replace the clutch as well. For that you'll need a clutch alignment tool. They're not expensive and you won't get the tranny back in without aligning the clutch.
GilaMtnJeep is offline
post #4 of 9 Old 09-24-2008, 05:25 PM Thread Starter
Brandon97TJ
What is the screeching sound though? I couldn't see a bearing making a noise like that.
post #5 of 9 Old 09-24-2008, 05:36 PM
NH2112
A dry bearing under a load and turning at 700ish RPM will definitely squeal. I second replacing the whole clutch assembly while you have the tranny down. From what I hear you don't have TJ flywheels resurfaced, just use a coarse Scotchbrite pad (or even better a "cookie" on a die grinder) and put a nice circular scratch pattern all over the engagement surface.
Phil
'90 YJ w/4.2l & 4.0l head, Weber carb, 5-speed, 4" RC lift, 33x10.5x15 BFG MT KM2s.
NH2112 is offline
post #6 of 9 Old 09-26-2008, 11:24 AM Thread Starter
Brandon97TJ
Ok so I called the shop to get this fixed and they said I would also have to get my flywheel resurfaced and my slave cylinder would also go bad in a few months if I didn't change it. I know not to get the flywheel resurfaced but I never heard about the slave cylinder going bad?
post #7 of 9 Old 09-26-2008, 12:54 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The throwout bearing going bad isn't going to cause the slave cylinder to go bad. And to confirm, don't let anyone turn/resurface the flywheel. Doing so would remove its required dome shape.
Jerry Bransford is offline
post #8 of 9 Old 09-26-2008, 02:26 PM
bruker
To keep your clutch from getting depressed try giving it some Prozac, then it might not make those horrible sounds.
I'm sorry, it's Friday.
Sure a spoonful of Draino will clean you out, but it will also leave you feeling kind of hollow inside....
bruker is offline
post #9 of 9 Old 09-26-2008, 02:54 PM
jeffyp06
2006 WK
if your going to go through the trouble of dropping the tranny why not just replace the whole clutch assembly?
jeffyp06 is offline
clicking/creaking noise when clutch is depressed?? NOjeeper TJ Wrangler Technical Forum 9 07-15-2009 07:45 PM
New clutch making noise wmujeep TJ Wrangler Technical Forum 6 06-01-2009 06:57 PM
Rattle/clack noise when clutch depressed at low RPM alex_c YJ Wrangler Technical Forum 4 05-27-2009 05:44 PM
Grinding noise with clutch depressed 1rockhead YJ Wrangler Technical Forum 6 08-26-2008 10:07 PM
My clutch is making a strange noise +GRAVES+ TJ Wrangler Technical Forum 11 04-03-2008 08:59 PM
