Help. Check engine light on but no codes stored - JeepForum.com
post #1 of 19 Old 11-03-2010, 06:24 AM Thread Starter
WhatBump1
WTF....Check engine light on , but no code....I stopped at a shop, just to make sure my computer worked, the check engine light stays on, no codes, what is going on
and stumped
97 TJ Pearl Blue I6, 5 spd,
85 CJ7 Laredo 4.2 with HEI fuel Injection (project)
BMW Z4 M Coupe to Jeep TJ to Jeep CJ7 to BMW R1200C
WhatBump1 is offline
post #2 of 19 Old 11-03-2010, 06:59 AM
nikeo02
That cannot happen, by definition. But if you are having this error, a common cause is a misfire. Misfire codes can disappear after some time without a misfire. The light should go off in turn though. If they cant clear it with the scanner, i would try a "hard clear" by disconnecting power for a while. Good luck.
2003 Yellow TJ
nikeo02 is offline
post #3 of 19 Old 11-03-2010, 10:25 AM Thread Starter
WhatBump1
tried that ... did not work either..? now i am really stumped
post #4 of 19 Old 11-03-2010, 10:55 AM
YellowX
YellowX's Avatar
Is your CEL on or "Check Gauges" light?
Fred
JAFGJ
YellowX is offline
post #5 of 19 Old 11-03-2010, 10:57 AM Thread Starter
WhatBump1
nope
only the Check engine, and I stopped allready at 2 shops and their comps say no code
post #6 of 19 Old 11-03-2010, 11:01 AM
biffgnar
biffgnar's Avatar
Loose wire somewhere getting power to that bulb?
Romney in 2020!
biffgnar is offline
post #7 of 19 Old 11-03-2010, 11:40 AM
fishinjeeper
x2
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #8 of 19 Old 11-03-2010, 01:59 PM
Jonny Jeep
Jonny Jeep's Avatar
Possibly a bad connection to the OBDII port or no power to it. Power is from the same fuse that supplies the courtesy lamps so if they are OK the connector should have power. Did you know that on a 97 you can get two digit codes from the cluster...?
http://www.jeepforum.com/forum/f9/fa...-codes-778086/
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #9 of 19 Old 11-03-2010, 02:23 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I edited your thread title.
"Help" is a little vague.
Wheelin98TJ is offline
post #10 of 19 Old 11-03-2010, 02:25 PM
smotrs
Gas cap tight? Can't recall if there's a code when the gas cap is too loose.
smotrs is offline
post #11 of 19 Old 11-03-2010, 02:28 PM Thread Starter
WhatBump1
Thats all I could think of, finally got the TJ running perfectly so if there is no code is nothing wrong, or is there no code because there is nothing wrong except a bad connection, or ...? driving me nuts...
I should be working on my CJ7 resto.
post #12 of 19 Old 11-03-2010, 02:36 PM
MikeyJ
Unplug battery terminal cables and touch them together for 5+ minutes... Reconnect and see if light goes away.
MikeyJ is offline
post #13 of 19 Old 11-04-2010, 10:16 AM Thread Starter
WhatBump1
did that ...still the same
post #14 of 19 Old 11-04-2010, 08:36 PM
TJJP77
TJJP77's Avatar
It could be a failed OBDII monitor "readiness"...I'm not sure these leave a code, but a good code scanner will have a mode to check OBDII monitor status and it will tell you which ones have failed.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #15 of 19 Old 11-04-2010, 08:48 PM
hefightsfire
It does leave a code but this can't be it. In order for the gas cap to throw the code it takes a while and his light has been coming right back on after having been reset.
hefightsfire is offline
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 06:05 PM
Need help with check engine light codes ReyesYJ YJ Wrangler Technical Forum 0 03-02-2009 08:51 PM
check engine light= no codes vargeg60 TJ Wrangler Technical Forum 5 03-11-2007 08:01 AM
Check engine light and codes Muddman TJ Wrangler Technical Forum 5 10-13-2005 08:03 PM
check engine light codes asjeep TJ Wrangler Technical Forum 2 09-12-2003 08:04 AM
