HELP!!! Changing signal/marker bulbs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > HELP!!! Changing signal/marker bulbs
ExtremeTerrain GROUP BUY: Barricade Rear Bumpers/Tire CarrIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteering and more from Ruffstuff!
Unread 06-07-2014, 11:00 AM   #1
SaharaStoked
I cut out my stock turn signal/marker housings and want to run something new non LED...but can't find any info that explains what to do when running the 3 wire to 2 wire and still making the signal and marker work like stock...please help
99 4.0 Sahara
5-speed
SaharaStoked is offline   Reply With Quote
Unread 06-07-2014, 11:39 AM   #2
athos76
http://www.jeepforum.com/forum/f9/2-...ite-up-933239/
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline   Reply With Quote
Unread 06-07-2014, 01:33 PM   #3
SaharaStoked
That didn't work for me...my dash lights stay on constant when the markers are on or full markers and head lights...I did that entire set up and nothing worked :/
99 4.0 Sahara
5-speed
Unread 06-07-2014, 03:29 PM   #4
SaharaStoked
Also that write up is for LED...but I didn't install the led relay that was mentioned...would you definitely need that relay regardless of led or not?
And that would make my turn signal lights on the dash work properly instead of steady ON?
That's my main issue
99 4.0 Sahara
5-speed
Unread 06-07-2014, 07:52 PM   #5
po5000
hi I changed out all the outside lights but the head lights to led and with the lights off everything is fine but with the lights on the turn sig. lights light up in the dash and then blink when I turn the turn sig switch. any way to make them work like stock?
po5000 is offline   Reply With Quote
Unread 06-08-2014, 08:19 AM   #6
SaharaStoked
I was having the same problem so I just use the main turn signal wires...the plug with 3 wires has the wire for the running lights...I just didn't splice into that one wire
99 4.0 Sahara
5-speed
Unread 06-08-2014, 08:20 AM   #7
SaharaStoked
Still want to figure out why this happens and where I can get the EP-26 flasher because nobody carries it anymore...
99 4.0 Sahara
5-speed
Unread 06-08-2014, 10:47 AM   #8
athos76
All of my local auto parts stores carry the EP26. Did you ask at the counter?
Unread 06-08-2014, 11:51 AM   #9
Rubi4MyMrs
Tks 4 the upgrade MoodyJP
Rubi4MyMrs's Avatar
How do you have it wired? What bulbs are you using?
If the signal indicator(s) come on when the lights are on there is feed back through the parking light circuit.
Rubi4MyMrs is online now   Reply With Quote
Unread 06-09-2014, 08:32 AM   #10
SaharaStoked
Yes I asked at the counter and called all my local auto parts stores :/
The cosset that had it was over an hour drive...rather just get it on eBay or Amazon at that point
99 4.0 Sahara
5-speed
Unread 06-09-2014, 08:34 AM   #11
SaharaStoked
Originally Posted by Rubi4MyMrs
How do you have it wired? What bulbs are you using? If the signal indicator(s) come on when the lights are on there is feed back through the parking light circuit.
Just like the OP did it in the write up
The diode and resistor together going to the blinker wire and just the diode going to the parking wire...I tried with and without LED lights the bulb was a 12v 3.4 watt
99 4.0 Sahara
5-speed
Unread 06-09-2014, 12:34 PM   #12
Rubi4MyMrs
Rubi4MyMrs's Avatar
If you have a 2 filament bulb & 3 wire socket for the front & a single filament 2 wire socket for the side marker & wire them up like the original with the 2 wires for the marker wired with one to the parking light wire & the other to the signal wire for the front light & the 3rd wire there going to ground everything should work & no need for resistors or diodes.
Unread 06-09-2014, 01:41 PM   #13
SaharaStoked
This I already know...but there are no housings out there for the 2 filament bulbs...and the ones I did find are either too big or not what I'm looking for...that's the downfall here and what I'm trying to avoid
99 4.0 Sahara
5-speed
Unread 06-09-2014, 02:02 PM   #14
Rubi4MyMrs
Rubi4MyMrs's Avatar
I guess I misunderstood when you said 3 wire to 2 wire. I thought you meant wiring the 3 wire fronts to the 2 wire side sockets to get them both to work.
You want to put a single filament bulb (2 wire socket) on the front & the same type for the side? Then you want to get the front to be on for parking lights & still blink for the signals like the side ones do normally?
Unread 06-09-2014, 06:52 PM   #15
po5000
just changed out the bulbs but I did install rear light guards that's it, it is making me nuts.
