Help! can't get bikini top off - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Help! can't get bikini top off
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Axles at CCORRough Country Lift Kits and Parts!
Unread 04-20-2015, 06:26 PM   #1
Randyfukeway
I just bought a 1998 Wrangler TJ. It has a bikini top, & the previous Owner did not show me how to take it off. In fairness, I was excited to get it, & it was raining so I took off before I got a tutorial. I watched a Youtube tutorial video, & there were two latches along the top of the windshield on the video that were opened to remove. The brackets on mine have a bolt on the top and will not budge. I will take the bolt out, but I don't want to break something. I do not know the manufacturer, so I hope someone can help. I realize I am not giving much information, but this is all I know at this point. I have attached a pic, but it is upside down.
Randyfukeway is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 07:12 PM   #2
TimV
You have to loosen the two bolts. That's a bolt on style header channel, as opposed to the clamping style used from the factory. Probably a 1/2" socket.
It's not an addiction. It's a way of life.
TimV is offline   Reply With Quote Quick reply to this message
Unread 04-20-2015, 07:52 PM   #3
Randyfukeway
Thanks TimV! I thought that may be the case.
Unread 04-20-2015, 08:33 PM   #4
Randyfukeway
I'm still missing something. The top across the cab from top of door to top of door is so taut I can't get the retainer clip out of the slot along the top of the door. I think something else needs to be tak e n off.
Unread 04-20-2015, 09:42 PM   #5
TJDaveX
Fail rated
TJDaveX's Avatar
That is a no drill header. Loosen the bolts with a half inch wrench until the clamping hooks can be pulled out from the holes in the windshield frame.
Sounds like the bikini top is being used with the door surrounds. This makes the top very tight. There is a plastic rail on the top that goes into the slot on the door surrounds, like the soft top does. It's a very tight fit, and hard to get them on and off.
Take a flat screwdriver and CAREFULLY pry the rail out of the surround at the rearward side to get it started, then finish by hand.
I get a good finger workout twice a year putting mine on and off.
TJDaveX is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 08:01 PM   #6
Randyfukeway
Thanks. I have decided to leave it on for now.
Unread 04-22-2015, 03:50 AM   #7
joe_jeep
Wait for a hot sunny sumner day.
They get alot easier to remove and install when is baking in the sun.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
