HELP! Broke a lug nut in half? Wheel Stuck On - JeepForum.com
post #1 of 32 Old 08-30-2010, 10:33 AM Thread Starter
richcz28
Broke a factory lug nut in half. Using a 3/4 inch socket and a bar I broke the top part of the lug nut off. The conical lower portion of the lug nut is stuck in the wheel and still threaded onto the stud. The entire section of the lug nut that the socket fits over broke off into the socket. I have aluminum stock style sport wheels on a 98 so the conical part of the lug nut is really buried in there. Any advice or ideas would be greatly appreciated. I don't mind getting a new stud pressed in but I do not want to ruin the rim getting it off.
Thanks.
richcz28 is offline
post #2 of 32 Old 08-30-2010, 10:50 AM
nuclearstrife
When I did my lift my factory lugs were stripping. I hammered on a smaller socket and that worked. Some use a cross bar and hammer it on, others use air hammer to loosen it. I would try the smaller socket first and see how you make out.
nuclearstrife is offline
post #3 of 32 Old 08-30-2010, 10:54 AM
530ktm
You may have to use an easy out. Drill the hole into the existing lug and then put the easy out into that and try and get it out. I have done this on exhaust manifold bolts in the past. Not sure if the lugs are hardened or not so that could be a tricky one.
530ktm is offline
post #4 of 32 Old 08-30-2010, 11:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
the studs are pretty soft.
you're going to have to drill it out and hope you get it straight.
ratmonkey is offline
post #5 of 32 Old 08-30-2010, 11:30 AM
yv4me
Maybe try to put a couple standard type lug nuts on there and break off the lug bolt, as close to flush with the lug nut as possibe. Drill out the remainder of the bolt just deep enough to remove the lug nut. Punch out the remainder of the stud and replace?
Expediency is no excuse for substandard work!
yv4me is offline
post #6 of 32 Old 08-30-2010, 11:35 AM
NotURMailman
NotURMailman's Avatar
I would just drill through the stud. Get incrementally larger on the drill bit until the stud is almost gone and the nut is loose. It should be easy enough to knock the rest of the stud out. Just be carefup not to drill the hole in the hub or you will have to find a wheel stud with over sized knurles. And even then you may have issues if you drilled off center...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is online now
post #7 of 32 Old 08-30-2010, 11:47 AM
yv4me
I'd rather try to drill through 3/8" than 1". If you drill crooked or break a bit, you'll end up having to break it off any way. Who knows, maybe it'll break off below the broken lug.
yv4me is offline
post #8 of 32 Old 08-30-2010, 11:51 AM
gabriel05
IF you have a D35 and you don't want to mess with trying to drill out the stud you could always just remove the axle shaft with the wheel/tire/brake drum still attached. Then grind the back side off the stud and pound it out from the back side. I know that sounds like over kill but if drilling isn't working for you, and you can't get a wrench on it that might be the only other option.
If you have room then try to weld the inside of a nut to the remaining portion of the stud.
Black Jeep Society Member
gabriel05 is offline
post #9 of 32 Old 08-30-2010, 12:35 PM
WillysEdition04
I've used a hammer and chisel to cut the nut off...
...used a cutting torch before too, but nicked the wheel a bit.
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #10 of 32 Old 08-30-2010, 12:49 PM
dcope17
I think this is a lot of work...
But will do the least amount of damage. Drill through it untill the walls of the stud get thin anough to break it... I would try that first but if things are not right... I think grinding off the back side of the stud will do the job the best.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #11 of 32 Old 08-30-2010, 12:55 PM
speepdaedeesi
just to be clear here, you arent saying you just broke the outer shell of the 2 peice lugs off right?
if all you broke off is the thin outer chrome shell, its an 18mm nut under that.
just making sure
89 yj stock- sold
92 yj stock- sold
97 tj 2"bb,31" tires- sold
95 yj soa,350 v8,sm465,44" tires,d60,14bolt- sold
95 yj soa,350v8,700r4,35" tires,d30, 8.8, fuel cell- sold
current ride-97 TJ- 86k miles, 4cyl auto, black casinos, 31" BFG A/T
speepdaedeesi is offline
post #12 of 32 Old 08-30-2010, 12:59 PM
ytowntj
When I bought my jeep i didnt have the key for the locking lug nuts the PO had on it and I took it to a local tire shop and they cut off all five (one on each tire plus the spare) locking nuts for 25$. When they finished there wasnt a single nick on the rims or the wheel studs.
So you could probably find a local tire place to do it and save yourself the headache...
ytowntj is offline
post #13 of 32 Old 08-30-2010, 01:16 PM
Louie4
I second a chisel and hammer. I've removed seized lug nuts this way before. It was a major PITA.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #14 of 32 Old 08-30-2010, 01:30 PM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
It sounds to me like half the people that are replying must have a read a different post then I did. CLEARLY he states that the lug nut broke in such a fashion that only the very bottom tapered portion of the lug nut is left. AND its on an aluminum wheel - so it will be very difficult to get in there to chisel it. Things like hammering on a smaller socket arent even an option....
OP - is this on the front or back? If its the back AND a D35 - the best way is to grind the back of the stud and pound it through - as suggested above. If its a D44 or in the front - my recommendation is to VERY carefully make some sort of a device to pound the stud through from the front side - effectively stripping the few threads that are left on the taper area of the lug nut. It should only be 2 to 3 threads, so I think with a 5lb hand sledge and some careful whacking - you should be able to break that nut. Good luck!
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #15 of 32 Old 08-30-2010, 02:01 PM
Chris in SC
Happened to me last fall. Local Goodyear store charged me $30 to drill out and replace the stud. Lugnut was another couple dollars.
Chris in SC is offline
Steering Wheel Stuck / High Beams Broke mazyj YJ Wrangler Technical Forum 2 11-16-2008 07:52 PM
Track Bar BROKE IN HALF at 30mph! SB99TJ TJ Wrangler Technical Forum 18 08-10-2007 09:51 PM
Spring broke in half, got a question... Richmond88yj YJ Wrangler Technical Forum 2 03-05-2005 05:13 AM
Broke a bolt in half......little help here... qadhafi YJ Wrangler Technical Forum 2 01-23-2004 10:37 AM
