Help!! Automatic Won't Go Into Gear! - JeepForum.com
post #1 of 24 Old 01-22-2009, 04:31 PM Thread Starter
Bodazapha
I pulled my jeep into the driveway with no problems. About half an hour later I went out to move it and couldn't get it into gear. The gear shift lever just slides from Park to 1 without engaging any gear. Any experience with this problem or help is greatly appreciated. Until I can move the jeep, both my parents cars are stuck where they are.
Bodazapha is offline
post #2 of 24 Old 01-22-2009, 04:33 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Get underneath on the driver's side and look at the front of the transmission where you'll see the shifter cable coming in from the front. After setting the parking brake where it can't roll, have someone shift the lever back & forth while you look from underneath to see what the cable is doing and if it's still connected to the transmission and moving. Odds are it's not a major problem, maybe just a bad cable or where it's attached.
Jerry Bransford is online now
post #3 of 24 Old 01-22-2009, 04:57 PM Thread Starter
Bodazapha
That was it. We found where it's disconected. It looks like the bushing that kept it on has just rotted away. What little there was left crushed in my hand when I touched it. Is there anywhere I can get a new bushing (tonight?) or an alternative? Thanks.
post #4 of 24 Old 01-22-2009, 05:08 PM
Jerry Bransford
Administrator
Can you take a good flash-lit photo of what came apart? You'd be darned lucky to find a replacement for what came apart in a hardware store at 7pm your time. You have a different auto tranny from what I have so without a pic, it'd be hard to know what you need.
post #5 of 24 Old 01-22-2009, 06:13 PM Thread Starter
Bodazapha
The area in the red cirlce is where the bushing used to be. We zip tied it on to get it in gear and out of the driveway. It worked, we just need the bushing now.
post #6 of 24 Old 01-22-2009, 06:23 PM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
My tranny is the same as yours, but it has not done that yet! But, something that did happen to mine, that is very common, is the plastic rod inside the shift lever breaks. (Shift interlock shaft) If you can't get it out of park, or in to park and lo gear, you will know what it is. There are some threads on this forum that show you how to fix it with a plastic hanger or chopstick. The dealer will try to replace the whole shift mechanism. My chopstick has been going strong and was free. Just a FYI. Happy Trails
TJDaveX is offline
post #7 of 24 Old 01-22-2009, 06:54 PM
2jhanna
what kind of material was the bushing, plastic, brass, steel, etc.
don't know the shape, but lowes harware bins has lots of different kinds of bushings.
good job on the zip tie.
jhanna
denton county, tx
2jhanna is offline
post #8 of 24 Old 01-22-2009, 07:43 PM Thread Starter
Bodazapha
It was a rubbery plastic. Old, deteriorating rubbery plastic.
post #9 of 24 Old 01-22-2009, 07:43 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
That happened to me recently. Its a single unit with the shifter cable. $120 for the cable and install, no its not covered under warranty.
Cable part# 52109624-AD $20, $97.50 labor.
Its a plastic snap type ring that is part of the cable end.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #10 of 24 Old 01-27-2009, 10:07 AM
mps925
Any updates on how you fixed it? My 05 TJ just did the same thing on Friday, and the Jeep dealership in town just closed down.
mps925 is offline
post #11 of 24 Old 01-27-2009, 12:27 PM
Jeepsr4me19
1976 CJ5
I found one of those pieces on a Grand Cherokee. I was at a pick a part place.
Jeepsr4me19 is offline
post #12 of 24 Old 07-24-2010, 07:36 AM
Jagans
2005 JK Wrangler
I had the same problem
My wife was driving our 2005 Wrangler, 4.0 with auto trans to a friends house. She called me to tell me that when she got ready to leave, the shifter wouldn't go into gear. The lever moved up and down, but didn't engage the transmission. I went to the house and crawled underneath.....thank GOD that it's a Jeep and I didn't need to raise the body off the ground!
The linkage has a nylon bushing that holds it to the shifter lever. It crumbled into pieces somehow. The Jeep only has 50K miles on it. I manged to get it home by clamping a pair of vise grips to the shifter lever (pinning the linkage to it.
I called the local Jeep dealer and it's $24 for the linkage (52109624AD), you have to buy the ENTIRE linkage, they don't sell JUST the nylon piece. It sounds like this might be a common problem, after readying this thread.
I didn't want to take the entire shifter column apart, so here is what I did.
I went to Home Depot and bought an assortment of small rubber and nylon bushings in the hardware dept. Then I got a small assortment of cotter pins.
When I went back home and crawled under (after letting it cool down, that transmission gets really hot!) I had to trim one of the rubber bushings just a little to get it to fit into the hole. Then I pushed the linkage clevis onto the linkage and put a cotter pin to hold it. So far so good! The linkage has what looks like a ball joint at the tip, so the cotter pin holds. You have to use one that is pretty stout, so it won't work its way off.
Jagans is offline
post #13 of 24 Old 07-24-2010, 11:19 AM
Knight-Rider
I just have mine zip tied. A zip tie lasts about 6 or 8 months. When it goes, I keep a bunch of them under my seat.
I remember the feeling of disgust, leaving the dealer empty-handed. I thought it would be a $4.00 part.
Knight-Rider is offline
post #14 of 24 Old 07-24-2010, 12:14 PM
swtrucker
2011 JK Wrangler
(05 4spd Auto Linkage Failure)...look at this write up.. Tells you how to fix it permantely.
swtrucker is offline
post #15 of 24 Old 10-16-2010, 01:48 PM
grimmstrong
I have a 2006 Jeep Wrangler.
Okay, so here's my problem.
  • Jeep is stuck in neutral
  • The bushing broke
  • The shifter cable won't line up the the "ball"
At first, just the bushing broke. I had fixed it temporarily fixed it with the zip tie explained in the forum. Then, they fell off and I couldn't get the Jeep back into park. It thinks it's in park, because I can take out the key, but when I take off the emergency brake, it starts rolling down the driveway. I don't know if the Jeep has to be in park for the cable to line up, but any suggestions would be great.
grimmstrong is offline
Automatic Won't Go Into Gear! waldoo TJ Wrangler Technical Forum 10 12-19-2009 05:30 PM
automatic transmission won't go into any gear wrestler22491 YJ Wrangler Technical Forum 12 11-09-2009 10:06 PM
Help!!! Automatic Won't Go Into Gear Bodazapha YJ Wrangler Technical Forum 3 01-22-2009 06:17 PM
Automatic Trans won't go to 1st gear XJRichB YJ Wrangler Technical Forum 3 03-16-2008 01:46 PM
gear grinding, in an AUTOMATIC! n4phth4 TJ Wrangler Technical Forum 9 09-26-2004 12:01 PM
