Help. Airbag light on, blower fan inoperative, backup lights inoperative - JeepForum.com
post #1 of 9 Old 09-17-2012, 07:47 AM Thread Starter
obritt
Airbag light has come on, fan on a/c heater will not work, backup lights will not work. All are on the same circuit on wiring digram. Need help.
obritt is offline
post #2 of 9 Old 09-17-2012, 07:51 AM
vipperdave
just a through in the wind..... checked fuses?
vipperdave is offline
post #3 of 9 Old 09-17-2012, 08:44 AM
Holm-z
bad ground somewhere?
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #4 of 9 Old 09-17-2012, 12:31 PM Thread Starter
obritt
Checked the fuses, all good. How would I check the grounds?
obritt is offline
post #5 of 9 Old 09-17-2012, 12:48 PM
tj98
This is a long shot but I've also had this problem when I use the wrong key. I can start my Jeep with the key for my sons Jeep and vice versa.
Only the airbag light stays lit and the a/c doesn't work in his (no a/c in mine). Do you have another Chrysler key?
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #6 of 9 Old 09-17-2012, 01:32 PM
vipperdave
Really? thats intresting what are the odds of keys workign on other cars... i guess if you think about it only so many ways to cut a key lol...I dont have an electrical diagram with me, but any relays run that circut? You said its the same circut, so look for the relay and switch it with another relay that you know works... just an other thought.
post #7 of 9 Old 09-17-2012, 03:07 PM
DeFens
DeFens's Avatar
I just had exactly the same issue. After much forum searching, I replaced the ignition switch module - problem solved. Part was $43 at NAPA. Installation was very easy - there are a few threads and even a couple of YouTube videos that show how to change it out.
'98 TJ Sahara - 6 cyl. 5 spd. | Rancho 3" Lift | 32x10.5 pro comp | Centerline wheels | Turbo City, Tomken, Skid Row armor | Warn i8000 | Airaid intake | DIY rear swingaway and bumper
'02 Chev Z71 Avalanche | '06 BMW R1200GS | '02 BMW F650GS Dakar | '11 Husaberg FE390
DeFens is offline
post #8 of 9 Old 09-17-2012, 03:18 PM
Holm-z
Something like this?
http://www.jeepforum.com/forum/f9/tj...oblem-1328943/
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #9 of 9 Old 09-17-2012, 07:07 PM
tj98
Different keys, just enough slop in the switch that either would turn it. Just not allow it to work right.
I've also had the keys fall out wheeling w/o doors. Didn't realize it till I tried to shut it off. Fortunately they stayed in the tub.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
HVAC Blower Periodically Inoperative VegasMatt JK Wrangler Technical Forum 10 09-30-2012 11:25 AM
newbie here (hazards and brake lights inoperative) mikeyjazz TJ Wrangler Technical Forum 2 03-04-2010 05:45 AM
98 Cluster/Radio/Dome Light Inoperative BGR500r TJ Wrangler Technical Forum 5 11-26-2009 03:12 PM
Explain this One (lights inoperative after moving to windshield) PM Thor TJ Wrangler Technical Forum 9 11-04-2009 08:02 AM
horn inoperative jeep n00b YJ Wrangler Technical Forum 7 10-08-2008 11:00 PM
