Help..4WD linkage problem after disconnecting and raising tub?? - JeepForum.com
 6Likes
  • 1 Post By Mattific
  • 2 Post By olysteve
  • 1 Post By 1longcj
  • 2 Post By mrblaine
post #1 of 7 Old 08-20-2017, 10:58 PM Thread Starter
RickDel73
Hello, I've been preparing for a Safe T Cap on my 2000 TJ Sport. Not having any previous mechanical experience I've been researching and prepping for the past six months. I've been trying to learn in sections. I basically learn how something works, take it apart, and reassemble. My goal is to have an understanding of all the associated parts I need to know for when I'm ready to tackle the Safe T Cap (my Jeep is my only transportation, so I can't afford for it to be out of service for any extended period of time).
Anyhow, this week I learned to raised my tub a few inches for the clearance to weld the back side of the Safe T Cap, which I still don't have a clue how you guys are welding above / behind the upper control arm and brake cable bracket, but that's another story. In the process I disconnected the four bolts on the driver's side floorboard and disconnected the 4wd linkage bracket. When I went to reinstall the bracket it doesn't line up without a lot of force. Did I bend something or is there a trick to this? Or do I just apply the necessary force needed to line up the bolt holes? Nothing looks bent, but something doesn't seem right. Photo attached.
Thanks.
RickDel73 is offline
post #2 of 7 Old 08-20-2017, 11:14 PM
Mattific
You could try loosening the adjuster to get it back in place. Then just realign with the shifter and tighten
RickDel73 likes this.
Mattific is offline
post #3 of 7 Old 08-21-2017, 12:23 AM
olysteve
Or,,depending on your budget, get a cable shift like a Novak set up and never have to fiddle with it again. I love mine, I know for a fact that whatever twisted up position I have my jeep in I can shift the transfer case the same as if I was flat and level
Sent from my SM-T310 using Tapatalk
Clodhopper and RickDel73 like this.
olysteve is offline
post #4 of 7 Old 08-21-2017, 04:40 AM
GreenliftedTJ97
Green Jeep Club member # 456
New Jersey & you, broke together since 1787
GreenliftedTJ97 is offline
post #5 of 7 Old 08-21-2017, 07:47 AM
1longcj
Do you currently have a BL? If so, PO probably didn't install a relocation drop bracket on that side. Is the OE bracket hanging upside down in the picture?
Here's a cheaper alternative to the cable shifter.
http://www.advanceadapters.com/produ...ifter-bracket/
1longcj is offline
post #6 of 7 Old 08-21-2017, 08:49 PM Thread Starter
RickDel73
thanks guys.... I actually got it by forcing it up while my wife inserted the bolts. I may invest an alternate cable set up in the future, but for now it's working.
BTW, there's no BL (I meant to add that in the original post)
post #7 of 7 Old 08-22-2017, 06:07 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Next time, have someone slowly move the t-case shifter handle until the tub bracket moves up where it needs to be. If you have to force it, it isn't adjusted as correctly as it should be.
olysteve and RickDel73 like this.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
