help-4 wheel drive high is stuck - JeepForum.com
post #1 of 29 Old 02-17-2003, 03:24 PM Thread Starter
mysweetfracture
i was driving and i got stuck in a part a plow didnt get to and i took it out of 4 wheel low and put it into 4 wheel high for more power and after i got out i wanted to drive faster so i went to put it back and it only goes into nuetral it is stuck in 4 wheel high or neutral. i dont know what to do. i have a 5-spd 97 wrangler if that helps. anyone think maybe its frozen? cause there is a good deal of snow stuck under there.
thanks in advance
mike
mysweetfracture is offline
post #2 of 29 Old 02-17-2003, 03:55 PM Thread Starter
mysweetfracture
come on people please. this is killing me i dont know what is wrong and i cant drive anywhere.
post #3 of 29 Old 02-17-2003, 03:55 PM
asjeep
break away the snow, but as i recall the system is run using vcum lines...perhaps you pulled one loose witht he snow (i may be wrong about it having vacum lines though)
2002 TJ SE
asjeep is offline
post #4 of 29 Old 02-17-2003, 03:57 PM
Owen
Owen's Avatar
Will the jeep not physically allow yuou to put it into 2wd?
I would try rolling backwards and see if you can do it then with the jeep out of gear.
Also Be careful breaking away the snow and see if you can see anything broken.
I live in NJ so I feel your Pain...
Smuggler Re-Born.....
Owen is offline
post #5 of 29 Old 02-17-2003, 03:58 PM Thread Starter
mysweetfracture
i dont know this is my first jeep i dont even know what to look for.
post #6 of 29 Old 02-17-2003, 03:59 PM
Owen
Owen's Avatar
Ok you have to shift the little handle to the right or left to get out of neutral..I almost freaked out the first time I did this. Make sure you are using the shift pattern correctly
Owen is offline
post #7 of 29 Old 02-17-2003, 03:59 PM Thread Starter
mysweetfracture
what am i looking for or around here help me out please guys.
post #8 of 29 Old 02-17-2003, 04:01 PM Thread Starter
mysweetfracture
ok well i have sat ther efor like 10 mins and wiggled the hell out of the handle and this thing will not engage into 2wheel or 4 wheel high. i am going to try again. ****ing snow! keep the info coming though all is appreciated thanks guys.
post #9 of 29 Old 02-17-2003, 04:02 PM
asjeep
if it has vacum lines wich engage the 4wd system ( i think they use this...)
they should be small black air tubes (vacum tubing) one could have popped off from soemwhere...
once again i stand to be corrected
2002 TJ SE
asjeep is offline
post #10 of 29 Old 02-17-2003, 04:02 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Hehe, they ditched the vacuum lines in 95..
mysweetfracture: Hopefully the problem is a linkage issue. As cold and wet as it is, take a peak under the Jeep and check out the Acme Cartoon Lever system they used. If it came loose or was set incorrectly, you'll have a hard time shifting the T-case. You can maunaully switch it from there if needed.
90% of the problems are there. Otherwise the issue is inside.
K9Jeep
K9JEEP is offline
post #11 of 29 Old 02-17-2003, 04:07 PM Thread Starter
mysweetfracture
ok help me out on where to find this?
post #12 of 29 Old 02-17-2003, 04:10 PM
Owen
Owen's Avatar
Under the Jeep you should see the Linkage next to the transfer case right where the Lever goes through the floor. Don't force the lever from the inside but make sure you are pushing it the right way when you are trying to get the Jeep back into 4wd high or 2wd. Without being in My Jeep I believe you pull the lever towards you from the inside from Neutral
Owen is offline
post #13 of 29 Old 02-17-2003, 04:22 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Have someone sit inside the Jeep and toggle the 4x4 level, you'll see how it all mechanically works.
Linkage system
Screw that usually needs adjustment.
K9Jeep
K9JEEP is offline
post #14 of 29 Old 02-17-2003, 04:36 PM Thread Starter
mysweetfracture
ok well i have a covering blocking most of my view do i look under the passenger side or drivers?
post #15 of 29 Old 02-17-2003, 04:44 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Driver's side.. Again, have someone toggle it for you so you can see...
K9Jeep
K9JEEP is offline
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 10:45 AM
Steering Wheel Stuck / High Beams Broke mazyj YJ Wrangler Technical Forum 2 11-16-2008 07:52 PM
Help, stuck in 4 wheel drive BamaWrangler YJ Wrangler Technical Forum 17 06-01-2008 08:21 PM
91 yj stuck in 4 wheel drive metfan34 YJ Wrangler Technical Forum 2 09-29-2007 06:45 PM
