HELP! 4.0L overheated, cracked block, now I need a new motor. - Page 5 - JeepForum.com
post #61 of 62 Old 10-22-2012, 10:04 PM
joe108
^ agreed, that's what happens when "techs" (aka parts swapers) try to be mechanics
joe108 is offline
post #62 of 62 Old 10-23-2012, 07:32 AM
dgi
I did the same thing bro!
My radiator blew up (10 years old at the time) and it caused me a world of hurt..
My head ended up being cracked so I bought a reman head, new radiator, water pump, samco hoses, t-stat, t-stat housing, etc and I still had coolant consumption. We put some dye in the coolant and ran a black light over and under the car, nothing.... No coolant/oil mixture... no smoke out of the back. I ended up getting tired of hauling around coolant and water so i got some bars leak and since then, i havent had to add coolant. Of course my motor only keeps oil pressure with 20w50 weight oil now (dont know if this is a related issue) but im getting 20mpg and its running smooth. Turning my A/C on in the summer will send the temperature of the motor into the red zone though.
You have two options from what I've gathered from my experience.
1. Throw a used motor in there for $1500 ( $1000 with $500 install)
2. Get a rebuilt motor/stroker (around here its $2900 for a stroker with $500 install)
From what I understand... if your going to install a head, its best to remove the engine and plane the deck on these motors to ensure a complete seal.
Feel free to PM me with any questions.
FWIW: I'm waiting for my current motor to die then i'll be getting a Golen 4.6
dgi is offline
block , block test , engine , motor , stroker
Cracked Block Blues greatnorthern YJ Wrangler Technical Forum 6 05-17-2012 12:14 PM
cracked block moparjoe TJ Wrangler Technical Forum 4 01-04-2012 06:28 PM
Cracked Engine Block. Possible to just replace the block? jchav74 YJ Wrangler Technical Forum 11 05-12-2009 01:37 PM
Pulling motor! Cracked block!! wimpy76 TJ Wrangler Technical Forum 10 03-09-2007 08:18 PM
