Help! 2.5L Engine knocking sound w/ video - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Help! 2.5L Engine knocking sound w/ video
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete Good deal on Wheels
Unread 11-02-2009, 07:05 PM   #1
cyberlian
I am a new, first-time Jeep Wrangler owner. I got a great deal on the Jeep due to the aforementioned knocking sound coming from the engine. It is a 1999 Jeep Wrangler SE w/ a 2.5l engine and 139k miles.
We took off the valve cover a few days ago and ran it for a couple of minutes, but could not pinpoint the sound and did not notice anything obvious. It still has good oil pressure (40+) and we have drove it for 300+ miles since the knock started, without any noticeable change in the sound. So, I'm coming to the experts to see if anyone else might have some advice to offer.
Am I looking at a new engine? Or, should I try anything else first? The only mechanic we saw told us to drive it until it quits. Is that the best idea?
Let me apologize in advance for the poor audio. The transition to youtube seems to have added some background noise. You can hear the knock, but it also kind of sounds like the engine is skipping in the video, which it is not. Here is a link to the video:
YouTube - 2.5l Jeep engine knocking sound?
cyberlian is offline   Reply With Quote Quick reply to this message
Unread 11-02-2009, 07:27 PM   #2
2000jeeper
Sounds just like mine. Mine started knocking the other day to. I need to pull my oil pan down for a leak any way so i will check rods and such them.
If you have a long screwdriver or wooden broom handle put it against the block near the oil pan rails on both sides and the other end up to your ear and see if you can pinpoint a area where it is louder. do the same along the valve cover area.
My noise sounds to hollow to be a rod or main. from the sound yours is makeing it sounds the same as mine
AMSOIL DEALER
2000jeeper is offline   Reply With Quote Quick reply to this message
Unread 11-02-2009, 07:51 PM   #3
tlendt
If its holding good pressure it might be a wrist pin. I've done engine replacements on two 97s that were knocking (actually one took a complete crap) and it was bad piston wrist pin bores in both cases. The really bad one had nothing left in the #2 bore but a rod and wrist pin; the pieces of the piston were in the pan. Fairly easy to diagnose. Pull one plug wire at a time with the engine running. When the knock subsides that's your bad cyl. Also can drain your oil into a clean pan and look for the tell-tale sparkles of aluminum. The good part is you could do the piston/rod assy "in-frame". Good luck.
tlendt is offline   Reply With Quote Quick reply to this message
Unread 11-02-2009, 09:28 PM   #4
knomexx
To make sure it is coming from the engine internals you may want to remove the serp belt and run it for a few seconds and make sure the noise is still there. It sounds like you are probably gonna need to swap the engine though.
knomexx is offline   Reply With Quote Quick reply to this message
Unread 11-03-2009, 04:08 PM   #5
John1997
Engine knock in 2.5
I have a 1997 wrangler 2.5L that I just purchased as well for a good deal and it has the exact same noise. Mine did not appear to be as loud. I have it at the shop right now and they have torn it down and it needs a crank kit in it. They are charging me around $850.00 . Does anyone know if that is reasonable or to high?
John1997 is offline   Reply With Quote Quick reply to this message
Unread 11-03-2009, 04:13 PM   #6
John1997
Also it is better to just go ahead and replace the motor verse replacing the crank kit? I would hate to spend the money on that and then have other issues. Any advice would be helpful.
Thank you!
Unread 11-03-2009, 04:19 PM   #7
cmc1
my engine has been knocking like that for about 40 thousand miles.It has great oil pressure and runs great.probably a wrist pin.I havent heard a 2.5 that didnt do it.they make some noise brand new.I would investigate it further for sure.especially if its running good.
cmc1 is offline   Reply With Quote Quick reply to this message
Unread 11-03-2009, 04:26 PM   #8
hockeyplayer21
My jeep (when it was my friend's jeep) was making the same noises, and the #2 or #3 cylinder ended up going through the side of the block. I just replaced the motor with a used one that had 80k miles on it. Got it for $350.
hockeyplayer21 is offline   Reply With Quote Quick reply to this message
Unread 11-03-2009, 04:27 PM   #9
4.0l sahara
Pull 1 plug wire off at a time and see if that changes the noise. Then report back and let me know what happens. Also pull the serp belt and make shure it isnt a water pump etc.
4.0l sahara is offline   Reply With Quote Quick reply to this message
Unread 11-04-2009, 06:46 AM   #10
mdm
Farm Wheeler
You noise is about the same as what I had with a broken piston skirt.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 11-04-2009, 07:21 PM   #11
cyberlian
I went through each of the plug wires a few times with the engine running, but never noticed a real difference in the knocking sound. I haven't pulled the belt yet, but will try that next.
Unread 11-05-2009, 04:52 PM   #12
2000jeeper
Drop your pan. I have a feeling you will find a broken piston skirt. That was what mine had and i had the same noise. #4 skirt. Going to NAPA tomorrow to order parts.
AMSOIL DEALER
Unread 11-05-2009, 04:53 PM   #13
2000jeeper
Did you short block it or just replace the broken piston?
AMSOIL DEALER
Unread 11-05-2009, 05:06 PM   #14
mdm
Farm Wheeler
I'm in the middle of a 4.6L stroker build.
Unread 11-12-2009, 05:08 PM   #15
cyberlian
Thanks for all the advice. After pulling the oil pan, we found out that it was a broken piston skirt.
I decided to go ahead and get an ATK engine from advanced auto parts. We are also installing a new clutch, slave cylinder, water pump, and exhaust manifold (had a crack). This should hopefully take care of all the major problems for a few years!
