HELP! 01 tj vibs!!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > HELP! 01 tj vibs!!!!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 06-27-2015, 11:01 AM   #1
tjkeith01
Lifted my 01 tj to 4 inch RC lift with 33x12.50x15, now I'm getting some vibs. Think it's coming from the drive shaft but I'm new to the jeep world so I'm not really sure. Took a picture of how it sits maybe someone can help???
tjkeith01 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2015, 11:07 AM   #2
mukluk
Four inches of lift with a stock rear driveshaft and control arms on a TJ is pretty much a guarantee for vibes. You can install a transfer case drop or engine mount lift if you haven't already, but your best solution is going to be to install a double cardan rear driveshaft and SYE along with adjustable control arms to dial in the pinion angle.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now   Reply With Quote Quick reply to this message
Unread 06-27-2015, 11:08 AM   #3
Chase0808
It's most Likely your driveshaft. Did your lift kit come with skid plate spacers? It should reduce the vibration but it won't fix it completely. Anything around 4" of lift could use a new driveshaft and sye.
Chase0808 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2015, 04:06 PM   #4
MGoBlue
Your pinion angle is wayyy off! Look at this illustration:
You want 0-1 degree (depending on who you listen to) where the driveshaft attaches to the axle pinion, like the lower pic.
Don't fear the regear!
MGoBlue is offline   Reply With Quote Quick reply to this message
Unread 06-27-2015, 11:22 PM   #5
mukluk
That's true... if he had a double cardan shaft. Based on the Mopar sticker affixed to the driveshaft in his pic, pretty safe bet to say he is running a stock shaft and slip yoke.
2000 TJ SE
2005 LJ Rubicon
