Hello rust, we meet again... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Hello rust, we meet again...
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 07-25-2011, 09:36 AM   #1
chitownEMT
It rained like a fiend last night and apparently my soft top wasn't completely sealed. I have carpet in the front and it was soaked so I decided to take it out and let the interior dry. That's when I stumbled on a tremendous amount of surface rust and a lovely hole about the size of a golf ball that was completely rusted through. I didn't think to take a picture because I was so close to crying at what I saw. So the first pics are after about 2 hours with the angle grinder and flapper wheel to the surface rust.
[FONT="Verdana"][COLOR="DarkRed"]-98 Wrangler Sport Chili Pepper Red
[COLOR="Black"]|AX15|NV231|D35c Trac-Lok|2" BB|Bushwacker Pocket Flares|31x10.5 GY Duratracs|AR Outlaw II 15x8|Trektop NX|[/COLOR][/COLOR][/FONT]
In the long run men hit only what they aim at. Therefore, though they should fail immediately, they had better aim at something high.
- Thoreau
In the depths of winter, I finally learned that there was, within me, an invincible summer.
- Albert Camus
[B]Disclaimer:[/B] The advice given on this forum is free; however, its value may be much less than you paid for it.
chitownEMT is offline   Reply With Quote
Unread 07-25-2011, 09:39 AM   #2
chitownEMT
Next I used the angle grinder with a cutoff wheel and some tin snips to cut out patches where the rust was really bad. After that, it was a lot of Rustoleum rust inhibitor spray paint and some butyl rubber caulk on some new patches of 22GA stainless steel sheet metal. I used rivets to hold the new panels down. I know it's not the prettiest thing in the world, but it's better than it was before. I have to let the rubber cure for 5 days before I can paint over it, but it'll get one more spray of Rustoleum flat black then I'm going to bedline the whole thing. No more rusty floorboards for me!
Edit: For the record, that butyl rubber sealant is sticky as sin! That's why there are strands of it all over the new patches of metal. You literally touch it at all and it's coming with you. PITA.
- Thoreau
- Albert Camus
Unread 07-25-2011, 09:53 AM   #3
Lemmiwinks
Nice work man!
03' TJ, 4.0L, I6
Lemmiwinks is offline   Reply With Quote
Unread 07-25-2011, 10:01 AM   #4
2003RubiBlue
Looks good!!!
Quote MrBlaine:
"That's awesome advice. Anytime I have a difficult repair, I fix something else that's much easier to get to. This one time, there was a hole in the oil pan so I replaced the side mirror on the driver's door."
Wanted: Tuffy rear underseat drawer. PM me if you have one.
2003RubiBlue is offline   Reply With Quote
Unread 07-25-2011, 10:11 AM   #5
j_niko
I'd be proud to have that floor
2000 - Sahara
1997 - Sahara
j_niko is offline   Reply With Quote
Unread 07-25-2011, 10:29 AM   #6
chitownEMT
Thanks for the kind words! And proud to have which floor, the rusty one or the patched one? Hahaha
- Thoreau
- Albert Camus
Unread 07-25-2011, 10:46 AM   #7
rikkards
Welcome to the club. I have a spot to fix that is about 10" long where the round drain hole is. I have rocker guards that had a small hole in it which got plugged which then let everything stay in and rusted it out. I have cleaned it out and am planning on using POR-15 on the innards and then welding a patch over it. I then have to herculine the floor.
Also for yours I would look at getting the drain hole drilled back in and put back in the rubber plug. You could probably do a pilot hole from the underneath where that drain hole is.
Btw the floor is 18G not 22 (but 22 should do the job).
rikkards is offline   Reply With Quote
Unread 07-25-2011, 11:07 AM   #8
Brainwashed2566
looks good man, now bedliner that thing before it does it again
I'll fix it after the lift and tires. Really.
2005 White LJ= Daily Driver
1987 Black XJ= In Jeep Heaven
Brainwashed2566 is offline   Reply With Quote
Unread 07-25-2011, 11:33 AM   #9
rikkards
The biggest help is keeping the carpet out. The noise insulation sucks up all of the saltwater and never dries until spring. Bedlining will help a bit but not the section with the tunnel which is what I had rot out which is what happened to me. The only solution to that is keeping it empty and if you can, paint the interior of it the tunnel.
Unread 07-25-2011, 11:34 AM   #10
chitownEMT
Rikkards,
I am definitely going to redrill the drain plug hole. I'm just waiting for the rubber sealant to cure before I start messing with it. And hearing about your rust issues makes me feel better; I assume this is a common problem with TJs? Makes you wonder why Daimler-Chrysler didn't just use stainless steel for the floor pans and treat it properly. Probably because it makes too much sense haha.
And I plan on either using Herculiner or Rhinoliner as soon as the rubber is cured and I lay down one more coat of rust-inhibiting spray paint.
- Thoreau
- Albert Camus
Unread 07-25-2011, 12:10 PM   #11
Jonny Jeep
Jonny Jeep's Avatar
I wouldn't redrill the drain hole where it was. I'd pull the drain plug from the lowest part of the floor and replace it with a JK plug if I were you. You can get the JK plugs on ebay pretty cheap...
http://www.ebay.co.uk/itm/Swap-Steel-Floor-Drain-Plug-w-Rubber-Jeep-Wrangler-TJ-/370452726231?pt=Motors_Car_Truck_Parts_Accessories &hash=item5640b401d7
Here's a thread with info about the JK floor plugs......
http://www.jeepforum.com/forum/f9/co...-whew-1106780/
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals (FSMs) can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm
If the link doesn't work properly, look for the service manual link under Jeep Resources at the bottom of the page.
Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php
Jonny Jeep is offline   Reply With Quote
Unread 07-25-2011, 12:31 PM   #12
chitownEMT
Is the JK plug oval-shaped like the hole in the floor pan at the lowest point?
I couldn't figure out why there is a nice and easy circular rubber plug that's NOT at the lowest point of the pan, but at the lowest point there's a goofy oval metal plate with clips on the bottom.
- Thoreau
- Albert Camus
Unread 07-25-2011, 01:14 PM   #13
j_niko
Oh the patched one....I already have the rusty one.
2000 - Sahara
1997 - Sahara
Unread 07-25-2011, 01:46 PM   #14
rikkards
I think the reason for the rubber round one is not as a primary drain but to be able to ensure the tunnel is clear. Plus really the floor is pretty flat. That's why I think they put it there. When I got mine I ended up getting new oval ones which look like they changed the design (the JK were just coming out). The original ones appear to seal well while the new ones didn't my theory is that they recognized the sealing ones as being a bad idea after the fact as it trapped the water in and went with the non sealing ones so if there was any water it would have a way of escaping. Like I said, it's my theory so I would take it with a huge grain of salt. Granted it may let water in if you are doing a deep water crossing although with mats I would assume it wouldn't leak too much but at least it has some way to get out.
Here is what I have to deal with (yes it isn't completely cleaned up yet) and you can see the new style replacement plug to the right. All that is holding it in is two small clips which don't actually pull it in, they only hold it from leaving the hole. There is a lot of play.
Unread 07-25-2011, 01:48 PM   #15
ryan_289
Pics like these make me glad I live in the South! There are plenty of 20 plus year old rigs running around with no rust!
01 TJ sport. 4.0, manual. SOLD
52 Willys M38. Currently in pieces in my shop. FINISHED AND SOLD.
Currently Jeepless.
ryan_289 is offline   Reply With Quote
