Hella Fog Lights ??? - JeepForum.com
post #1 of 9 Old 04-22-2008, 08:52 PM Thread Starter
IrishRED
4-Banger Forever!
IrishRED's Avatar
I just installed a set of Hella series 500 fog lights and they don't work. During my troubleshooting, I noticed that the wiring to the H3 bulb had the ground wire attached to the back of the bulb and the "hot" wire to the metal frame around the bulb. This was the same on both lights which came pre-wired with the bulb installed.
To me this doesn't seem right. Yet at the same time I don't want to just switch the wires, hit the switch and watch the bulbs blow.
Does anyone have experience with the H3 bulb? Like I said, this doesn't look right to me but what do I know!
IrishRED is offline
post #2 of 9 Old 04-22-2008, 09:18 PM
juggle9
I had problems with my installation on those too. I ended up using a toggle switch that does not light up. Ran all the wiring from the battery through the supplied fuse and relay. Just had to splice into the low beam constant. Some people use the parking lights so they can have on only the fog lights and not the head lights. I have thought about doing this, just don't know what wire is for parking constant, not blinkers.
As for the ground wires, I do remember having to ground each bulb indivudually to my frame. Have to go look, but I am pretty sure the way it came from the factory is correct. I will run out to the jeep and see if it is. Just give me a minute.
Yellow Jeep Club Member 1179
USAF Jeep Club Member 36
There is more to life than MPG's!
juggle9 is offline
post #3 of 9 Old 04-22-2008, 09:28 PM
juggle9
Man, I wish I had a camera here at work. Imagine this. If you are looking at back of the light, there are two wires, one blue and one white, (connects to a black power lead on mine). The blue wire is connected to the outer silver case of the lamp, and the white wire connects directly to the back of the bulb inside the case. The white connects to power on the relay, the blue is your ground. I ran it back under the hood and used a ground bolt something else was using. Hope that helps.
juggle9 is offline
post #4 of 9 Old 04-22-2008, 10:03 PM
iceman123187
you need to make sure your ground the switch or they wont work.
1999 TJ|3" Black Diamond Susp.| 1.25 JKS BL| 1" JKS BMML|33x12.50's| 15x8 Eagle Alloys| 4.88 Gears| D35 and Detroit Tru Trac in the rear| D30| NATES 4x4 front and rear bumpers| Hella 500's| HI Lift| Rattle Guard Bed Liner
iceman123187 is offline
post #5 of 9 Old 04-22-2008, 11:09 PM Thread Starter
IrishRED
4-Banger Forever!
IrishRED's Avatar
So mine were wired wrong from the factory!! My blue ( ground ) wire was connected to the white wire to the back of the bulb while the black power wire went to the outer silver case. Yes the instructions did say to use the blue wire as the ground but I never checked the bulb wires themselves. Hope I didn't blow the bulbs with this mess.
I'll try switching them around tomorrow. Looks like I will have to recheck all the fuses and grounds again too as well as the switch and the relay. I did make sure the switch was grounded, as someone mentioned earlier.
I gotta say, I'm not impressed with Hella's documentation so far! In addition to this problem, the wiring diagram shows two different ways to attach the leads to the switch as well as being pretty vague in the first place.
Oh well, tomorrow's another day! Thanks for the tips!
IrishRED is offline
post #6 of 9 Old 04-23-2008, 04:37 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
I grounded the blue wires directly to the bolt that holds them on the bumper.I wired mine into the high beams directly with no switch.That way my high beams are HIGH BEAMS.I got the Hella 500 driving lights.
TheBoogieman is offline
post #7 of 9 Old 04-23-2008, 11:14 PM Thread Starter
IrishRED
4-Banger Forever!
IrishRED's Avatar
OK, I figured out my problem. The grounds for my lights were no good. I'm guessing it was the powdercoat on the bar. I had the lights grounded to the mounting bolts. Other people here said they have done that and it worked but not for me. Once I moved them to a different grounding point all was well!
I am still very annoyed that the lights came wired backwards from the factory. Or maybe the lights were OK and the wiring diagram was messed up but it definately said to use the blue wire as the ground and that was the wire they had attached to the bulb!
Not very impressed with the documentation that came with these lights!
IrishRED is offline
post #8 of 9 Old 04-24-2008, 07:43 PM
TOP HVY
I bought a set of the Hella 500 driving lights and the install was a snap! I just removed the factory wiring from the back of the factory fogs, ran the factory wires into the back of the Hella fogs and plugged them right in. Couldn't believe they hooked up exactly the same as the stockers.
John
98 Jeep Wrangler Sahara
_______
--(O|||||||O)--
White Jeep Club Member #93
TOP HVY is offline
post #9 of 9 Old 04-27-2008, 01:09 PM Thread Starter
IrishRED
4-Banger Forever!
IrishRED's Avatar
That would have been nice but my TJ didn't have factory fog lights.
They look good and they work so I guess I can't complain too much!
IrishRED is offline
Can you splice Hella fog lights into factory fog lights? Nerv TJ Wrangler Technical Forum 21 12-19-2008 05:48 PM
Hella 500 lights ScottD06X TJ Wrangler Technical Forum 14 07-05-2007 06:07 PM
Hella Lights alvinl TJ Wrangler Technical Forum 4 05-26-2007 07:15 PM
Hella Lights chuck09 TJ Wrangler Technical Forum 7 10-23-2006 09:26 AM
New Hella Lights onlyone TJ Wrangler Technical Forum 3 06-20-2005 10:20 PM
