Helicoil for Stripped Front Caliper?? - JeepForum.com
post #1 of 23 Old 09-04-2007, 07:11 PM Thread Starter
gtospeeding
one of The threaded holes in my front spindle is stripped where the caliper bolts to it. Im going to need a helicoil but Im not sure where to find one any ideas who carries them?
99' 4.0 tj
gtospeeding is offline
post #2 of 23 Old 09-04-2007, 07:15 PM
skruske
Do not bet your life on a ruined thread.
Replace the caliper & sleep well.
edit to add.... my misunderstanding. If the hole that stipped is in the caliper braket? Then I agree with Gary Jeep Mud, auto parts stores have a simple fix for this common problem.
skruske is offline
post #3 of 23 Old 09-04-2007, 07:16 PM
gary_jeep_mud
1978 CJ7
I don' t know anything about helicoils, but when this happened to me I went to NAPA autoparts and bought oversized caliper bolts, they worked great. they come with locktite in the package. just tell them your make, model, and year, they stock thousands, thats what she told me. good luck.
-gary
2002 Jeep Wrangler Apex, 4inch Rough Country Lift, 33x12.50 BFG Mud, 15x10 Eagle Alloys, Fabtech Front Bumper, 4real Rock Rails, Herc'd Tub, P/s Box Armour, Uniden CB, Fleetpride H/D Front Driveshaft
I Wave, Do You????
gary_jeep_mud is offline
post #4 of 23 Old 09-04-2007, 07:25 PM Thread Starter
gtospeeding
-gary
an oversized bolt wouldnt fit thru the sleeve in the caliper
post #5 of 23 Old 09-04-2007, 07:32 PM
Lostj
Lostj's Avatar
same thing happened to me yesturday. I just got a couple helicoils that fit on the caliper bolts and got em on with those
00'TJ
74'CJ5 For Sale
Lostj is offline
post #6 of 23 Old 09-04-2007, 07:42 PM Thread Starter
gtospeeding
where did you buy the helicoils from?
post #7 of 23 Old 09-04-2007, 07:42 PM
kingvm
kingvm's Avatar
2005 WK
Here is your magic potion.
http://www.jeepforum.com/forum/showt...hlight=caliper
I just did this about a month ago myself and it is a great kit with all parts needed and good directions.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline
post #8 of 23 Old 09-04-2007, 07:43 PM
gary_jeep_mud
1978 CJ7
just the threads are oversized, they work.
-Gary
I Wave, Do You????
post #9 of 23 Old 09-04-2007, 08:26 PM
Lostj
Lostj's Avatar
i didnt buy em, my buddy had some already but ive seen em at a bunch of different autoparts stores and a couple "bolt specialty" shops
00'TJ
74'CJ5 For Sale
Lostj is offline
post #10 of 23 Old 09-05-2007, 01:02 AM
badtux
Any good auto parts store (i.e. *NOT* Auto Drone) will have Helicoil stuff. The resulting repair is usually as strong as the original. Be prepared for sticker shock. I buy my Helicoil stuff at Winchester Auto Supply in Campbell, CA, but most NAPA ought to have it too. Get the "kit" with the drill bit and inserter.
badtux is offline
post #11 of 23 Old 09-05-2007, 01:15 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Helicoils are typically better in blind holes that have a bottom.
You are better served with a solid insert. I like the Timesert brand due to the flange, but they are so expensive and hard to buy in small quantities, about the only way to get them is to know someone at an auto shop that uses them.
If you do find some, the thread size is 8mm x 1.25 pitch. Just make sure you borrow the cutting tool to cut the counterbore for the flange.
A reasonable alternative is the EZ-Lok brand with the American external threads. Be aware that the dry patch loctite 271 on them is fairly useless and should be removed and liquid Red 271 Loctite used instead.
I did a lot of testing on the EZ-Loks after reading about some folks having issues and figured out a decent solution with the liquid. Also note that I tested the gel stick Red Loctite and found it didn't hold very well either.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #12 of 23 Old 09-05-2007, 03:35 PM
GCJoe
GCJoe's Avatar
I had a similar problem on my better half's Durango this weekend. I was able to get a tap from Napa and clean up the threads from the back side. The guy at Napa said if that didn't work they had a bolt with oversized self tapping threads made just for this issue. Lucky for me the tap worked. Good Luck!!
GCJoe
2001 XJ
Bone Stock
GCJoe is offline
post #13 of 23 Old 09-05-2007, 08:01 PM Thread Starter
gtospeeding
I went to my local NAPA they didnt have oversized caliper bolts for a jeep, only GM products.
Does anyone have a NAPA part # for oversized caliper bolts for a Wrangler?
post #14 of 23 Old 09-05-2007, 08:08 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I went to my local NAPA they didnt have oversized caliper bolts for a jeep, only GM products. I dont get it
I've been pondering this my ownself. I'm trying to figure out how you get oversize threads through a sleeve that is the correct internal diameter without drilling out the sleeve, in which case I'd be a bit concerned about it's final strength and ability to work correctly.
Having played with a few hundred jeep calipers, I'm a tad confused.
I am Savvy
mrblaine is offline
post #15 of 23 Old 09-06-2007, 08:37 AM Thread Starter
gtospeeding
-gary
dont listen to this guy, hes giving out FLASE info.
Stripped Brake Caliper Bolt at the knuckle JeepRocks86 TJ Wrangler Technical Forum 19 05-08-2010 06:59 PM
Caliper bolt stripped, how to get off? TheDragonfly TJ Wrangler Technical Forum 33 12-22-2009 07:52 AM
Bottom bolt on front brake caliper stripped athos76 TJ Wrangler Technical Forum 1 08-09-2008 04:41 PM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 05:46 AM
Skid thread stripped -- Helicoil or ??? Jack Flesher TJ Wrangler Technical Forum 6 08-21-2004 07:21 PM
