Heavyweight oil for my 2001? - JeepForum.com
post #1 of 16 Old 06-20-2012, 01:40 PM Thread Starter
TJSunny1
So I have a 2001 with what I think is low oil pressure. At hot idle its at about 12psi and at 1300 RPM its at about 35 psi. What concerns me is when I do a hot start, it takes up to 7 or 8 seconds to create pressure and the check gauges light comes on.
I guess I have two questions: Is this normal? Would putting a heavier oil in help the problem?
I run 10w30 right now.
Thanks!
TJSunny1 is offline
post #2 of 16 Old 06-20-2012, 02:10 PM
lwszabo
Heavier oil is not a good idea. The vehicle was designed for a certain oil and that's what it needs. You need to find out what the problem is and not try to mask it. Start with the cheaper stuff like sending units etc...good luck!
lwszabo is offline
post #3 of 16 Old 06-20-2012, 02:39 PM
danb303
How many miles?
Typical signs of worn bearings. I would go to a little thicker oil and give that a shot. Lots of people go to Rotella. Trying a new sending unit might be worth the $
I would try the Valvoline Racing oil VR-1. My brother swears by it, says it has quitened his down a lot.
Make sure you are using a good filter... I run Wix. I had an issue with a Mopar filter and haven't used one since
danb303 is offline
post #4 of 16 Old 06-20-2012, 04:20 PM
lwszabo
Originally Posted by danb303
How many miles?
Wix makes Mopar filters!
lwszabo is offline
post #5 of 16 Old 06-20-2012, 04:29 PM
BioTex
1979 CJ7
Install a mechanical guage so you are taking a lot of guess work out of the diagnosis. Then report back what your "real" pressures are.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #6 of 16 Old 06-20-2012, 04:30 PM
lwszabo
Sorry I was wrong. Purolator makes Mopar
lwszabo is offline
post #7 of 16 Old 06-20-2012, 05:28 PM Thread Starter
TJSunny1
oh sorry. its got 127,XXX on the clock. And.....uhhh...a mysterious coolant leak..... But my oil shows no signs of contamination. Im gonna send a sample to blackstone though.
TJSunny1 is offline
post #8 of 16 Old 06-20-2012, 05:33 PM
BamaJeepman21
Originally Posted by danb303 View Post
How many miles?
Are bearings easy to replace or is it a major overhaul?
-Jack
BamaJeepman21 is offline
post #9 of 16 Old 06-20-2012, 06:21 PM
VietVet67
YES to the above try 20-40 and see if that helps at that mileage it won't hurt the engine maybe mileage a little--I run 15/40 in mine in Arizona all the time at 30K miles
Silver Jeep club member #76 Semper -Fi my brothers
VietVet67 is offline
post #10 of 16 Old 06-20-2012, 09:11 PM
appfire
My '98 is doing the exact same thing. 2.5 motor with No noise or rattleing in the motor, low oil pressure after the motor warms up. Mechanical guage shows the same pressure as the factory guage. Small coolant leak, no signs anywhere. Used some castrol 20w50 for a few days and did not really make much difference in the pressure when it warmed up. Also used some gunk motor flush and that also did not make any difference. I am assuming worn bearings. Anybody else have any other ideas?
Chris
All politicans are crooks. They should have to work and pay for everything like we do.
appfire is offline
post #11 of 16 Old 06-21-2012, 06:54 AM
danb303
Replacing the bearings is a major project.
What temp does your jeep run at?
If you can stay around 12-15 psi when hot then I wouldn't worry about it. LOTS of jeeps are riding around with the oil pressure that low... and LOTS of jeeps are running Rotella for that exact reason.
danb303 is offline
post #12 of 16 Old 06-21-2012, 12:54 PM
appfire
Temp is normal, always just below the 210 mark when fully hot. Its never overheated. I add maybe a cup of antifreeze every other week. When the motor is fully hot, the pressure guage will be around 15-18 psi driving 55mph down the road.
Chris
appfire is offline
post #13 of 16 Old 06-21-2012, 12:55 PM
appfire
Is rotella that much safer or better? What weight?
Chris
appfire is offline
post #14 of 16 Old 06-21-2012, 01:01 PM
JBTJ
Chris
No, it's no better than any other quality motor oil.
JBTJ is offline
post #15 of 16 Old 06-21-2012, 01:20 PM
danb303
It's just a HD 15w 40 motor oil. And its a quality motor oil. I don't use it but if I had one that was getting that close to 10 psi I certianly would try it. It's only around 14 bucks a gallon. Give it a shot
danb303 is offline
4.0 , check gauges , low oil pressure , oil , psi
Looking at a 2001 TJ wbellinz TJ Wrangler Technical Forum 3 02-23-2012 09:22 AM
Post 2001 to pre 2001 manifold swap ? wayfastwhitey44 TJ Wrangler Technical Forum 6 12-05-2010 01:55 PM
RB1 in a 2001? 79CHKCHK TJ Wrangler Technical Forum 4 05-09-2009 06:04 PM
2001 top on a 97? buckydano TJ Wrangler Technical Forum 9 07-11-2006 06:33 PM
I'm not a Heavyweight!... Scafone TJ Wrangler Technical Forum 2 07-04-2003 10:40 PM
