"Heavy Duty" Springs listed on build sheet? - JeepForum.com
post #1 of 3 Old 10-22-2005, 09:32 AM Thread Starter
IAJack
IAJack's Avatar
On my build sheet it lists heavy duty springs. I noticed in looking up parts if I were to order replacements there are the two types listed.
What exactly are these, how much bigger are they whats the difference and the deal? My Jeep originally came with a hardtop also. I have always thought it looked a little taller than some Jeeps - especially in the back.
NRA-Certified Pistol Instructor
IAJack is offline
post #2 of 3 Old 10-31-2005, 06:21 PM
bobsguns
Unless it's for a towing package, I wasn't aware of two different spring set-ups?
I live in a modest home with an immodest array of firearms.
bobsguns is offline
post #3 of 3 Old 11-01-2005, 05:53 AM
ncb76
ncb76's Avatar
The HD springs are just stiffer. They keep the Jeep from sagging when the hard top is on or towing. If you have the top off or a soft top with the HD springs, then you will probably sit higher.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
"SLIME" Pro Power Heavy-Duty Tire Inflator Chisow YJ Wrangler Technical Forum 13 04-09-2009 06:06 PM
Anyone Running OME 2.5" heavy duty lift springs od BDS 2.5" springs 1992 renagade YJ Wrangler Technical Forum 6 03-31-2009 07:12 AM
OME 2" lift Kit - Med or Heavy Duty Springs CTKen TJ Wrangler Technical Forum 16 04-10-2008 10:14 PM
"heavy duty suspension" factory option on JK? tlpvt JK Wrangler Technical Forum 10 12-18-2007 07:39 AM
HOSS vs carpeted "heavy duty storage cart" from Quadratec? sdebol JK Wrangler Technical Forum 0 03-23-2007 06:55 AM
