Heating/AC vent question - JeepForum.com
post #1 of 7 Old 07-26-2010, 12:16 AM Thread Starter
EJames1226
EJames1226's Avatar
When i turn on the air, it will blow fine for a few seconds and then it sounds like its getting blocked and no air will come out for a while and then it will start coming out like normal. Anyone else had this problem? Do i just need to take the dash apart and clean out the vents?
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #2 of 7 Old 07-26-2010, 02:01 AM
wushaw
Rockin jeep
wushaw's Avatar
Does it default to the defrost position when it quits comming out of the dash vents?
wushaw is offline
post #3 of 7 Old 07-26-2010, 02:16 AM Thread Starter
EJames1226
EJames1226's Avatar
Not sure but maybe. It just makes a noise like the air is blocked. ill check in the morning.
post #4 of 7 Old 07-26-2010, 12:16 PM Thread Starter
EJames1226
EJames1226's Avatar
Well for the first time since owning my jeep the air is blowing out the vents normally right now. Usually the air gets blocked about 10 seconds after turning the air on.
post #5 of 7 Old 07-26-2010, 12:19 PM
wushaw
Rockin jeep
wushaw's Avatar
Stranger things have happened, it will more than likely return.
wushaw is offline
post #6 of 7 Old 08-24-2010, 08:40 PM Thread Starter
EJames1226
EJames1226's Avatar
Old thread, but yes, the air starts coming out of the defroster when it stops blowing out the vents.
post #7 of 7 Old 08-24-2010, 08:52 PM
wrangler1977
Do a search on this. There is a couple of really good threads on this telling you what to test, where to look, and where to get the parts to fix. A lot of us have had this problem. Mine was a bad vacum elbow under my battery tray. I think most of them had issues with an actuator arm connect. Either way it was a pretty easy fix.
wrangler1977 is offline
air flow , HVAC , vents
Ignition key issue & heating question Sleuthhound YJ Wrangler Technical Forum 22 06-18-2010 03:39 AM
Radio question - something in my harness is heating up - anyone know what this is? chosos YJ Wrangler Technical Forum 17 04-04-2010 12:19 PM
ax-5 vent question nj95yj YJ Wrangler Technical Forum 5 06-12-2009 09:05 PM
Heating/Cooling question rompinthewoods YJ Wrangler Technical Forum 3 02-21-2009 06:02 AM
Garage heating question spshultz YJ Wrangler Technical Forum 30 12-01-2008 05:39 AM
