Quantcast Heater Not on settings 1 and 2 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Heater Not on settings 1 and 2
Old 08-06-2008, 10:57 PM   #1
armartel
Hey guys,
I have an '05 Wrangler and I was hoping that someone could tell me if they've had problems with their heaters not working on settings 1 and 2, but working fine on settings 3 and 4?
I did a search and came up with a few things, but most of them were for Liberty's...
armartel is offline   Reply With Quote
Old 08-06-2008, 11:04 PM   #2
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
By "heater" do you mean the fan that blows air? If so, then your "blower motor resistor" needs replacing. Search for "blower motor resistor" and find the write up.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/
dogbluedrummer is offline   Reply With Quote
Glock Forum
