Heater minus the heat. - JeepForum.com
post #1 of 5 Old 10-25-2005, 07:42 PM Thread Starter
Achped
2017 JK Wrangler
'99 4 cyl 5 speed Wrangler
I know I've been kind of bombing this forum with lots of questions lately, sorry
But I don't know where else to ask.
My heater doesn't get hot, at all.
I remember it getting warm once (only time I ever used it), since then I drained the radiator (and only the radiator yucky brown coolant) and since then it's never been the same.
I'm guessing air, but I've already bled the system multiple times and no more air bubbles are showing up.
Neither of the heater hoses get warm. The upper radiator hose does get warm, but it doesn't get pressurized at all.
I can seriously drive for an hour, and open the radiator cap and it won't spray out or anything.
I do know the radiator was replaced with the previous owner due to it "blowing up", but that wouldn't cause them to touch the t-stat would it?
My only guesses are bad t-stat, air, or just a faulty heater core (even though it did work before the radiator drain).
Any guesses, suggestions?
Oh yeah, since the recent cold front (temps <75) the temp gauge has been constant at what I'm guessing is 195ish.
Before that thoug, temps around 85-90, with the AC on and driving around 40mph it would be just a slight hair below 210. Idling with AC 215ish.
What's going on?
Achped is offline
post #2 of 5 Old 10-25-2005, 07:52 PM
Dirty Backroads
Dirty Backroads's Avatar
Sounds like you have a bad T-stat. Just because they replaced the radiator is no guarantee that the thermostat wasn't replaced. I'd start there. If that doesn't work I'd check the heater core. You could have a blockage or it could be leaky. Any leaks under the dashboard?
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
post #3 of 5 Old 10-25-2005, 07:58 PM Thread Starter
Achped
2017 JK Wrangler
I would say the t-stat, but the upper radiator hose gets warm instantly, like it just opened, and it gets warm right about where the temp gauge would be at 195. It just doesnt get pressurized.
I'll check it out, i just really hate t-stats...they always fall down as you're trying to put them in place and leak and bleh
How can you check the heater core?
No leaks.
Achped is offline
post #4 of 5 Old 10-25-2005, 08:19 PM
Dirty Backroads
Well, I'd start with the T-stat simply because they probably didn't change it and it's the most obvious. I hate changing them too.
Were the hoses themselves changed? It's strange that you aren't getting any pressure and I'm wondering about a blockage of some sort since the coolant had obviously been neglected at some point.
As for the heater core, if you aren't getting any leaks that's a good sign but unfortunately heater cores start to go right around the age your Jeep is. I'd start with the other things and eliminate them. They are cheap fixes. If you change the hoses you'd definitely want to pull off the heater core hose and check that as well. When I change the hoses I change 'em all.
post #5 of 5 Old 10-25-2005, 10:13 PM
CETROV
CETROV's Avatar
Restricted heater core -
if it is restricted the heater hoses will not warm up - no circulation.
Pull both heater hoses off and run water direct into the heater core and force out all the crap that is in it.
This will work -
Kirk
97 TJ
CETROV is offline
Heater will not heat LonestarTj TJ Wrangler Technical Forum 1 01-09-2010 10:01 AM
Heater won't heat. MazdaTed TJ Wrangler Technical Forum 17 12-11-2009 04:59 PM
How do I get more heat out of my heater? Tkahne88 TJ Wrangler Technical Forum 18 12-19-2008 05:09 PM
No heat from the heater? dell2028 TJ Wrangler Technical Forum 11 01-31-2007 09:25 AM
no heat heater sill YJ Wrangler Technical Forum 7 01-18-2002 10:59 PM
