Heater hose fitting replacement - JeepForum.com
post #1 of 3 Old 02-01-2009, 04:06 PM Thread Starter
superslayer
I was inspecting mine today and it looks like its rust rotting away from under the paint! So I'd like to replace it ASAP
Is it as simple as twisting the old one off the waterpump and replacing it (with using some teflon tape on the threads) or is it something that requires to pull the waterpump off to get to it.
Also i'm having a hard time trying to find one at autozone or advanced, is this a dealer only part?
Thanks!
superslayer is offline
post #2 of 3 Old 02-06-2009, 03:34 PM
Ford
I have the same problem with my TJ. Has anyone replaced this?
Thanks,
Ford is offline
post #3 of 3 Old 02-06-2009, 05:51 PM
2jhanna
don't know about a 2.5, but i have the same problem on my 4.0. all the below comments are based on a 4.0.
if it is the same part, i think it is a dealer only item. i have done some research and found that the threads in the water pump housing are standard pipe thread. my plan is not to remove the water pump. remove the old fitting, thread a standard brass pipe fitting in the w/p housing, put a 90* elbow, then a hose barb fitting for the heater hose. the use of all brass fittings, problem solved forever. any hardware store or even lowes/home depot has this stuff.
even if you get the fitting from the dealer, it will happen again.
jhanna
denton county, tx
2jhanna is online now
Water PUMP heater hose metal tube replacement. BC Jeep TJ Wrangler Technical Forum 5 05-11-2013 01:44 PM
Heater Hose Fitting leaking DeL2000 TJ Wrangler Technical Forum 3 01-29-2010 04:22 PM
Thermostat Hose Fitting vmann7 YJ Wrangler Technical Forum 11 10-13-2008 06:21 PM
Part Number for Water Pump Heater Hose Fitting Nitrox73 YJ Wrangler Technical Forum 3 11-28-2007 09:31 PM
Heater Hose fitting... JeeperJay YJ Wrangler Technical Forum 2 08-30-2001 12:41 PM
