heater help: not the usual heater problem - JeepForum.com
post #1 of 3 Old 12-05-2010, 06:51 PM Thread Starter
doug davis
I have a 97 4 cyl TJ with no AC.
The heat is marginal so I did the normal things: flushed the core, changed the thermostat, checked the operation of the diverter, mixture flap etc.
What I noticed is that when the mixture flap (temp control lever) is on full hot, the airflow through the outlets is severely restricted. Almost no air flows at all (what does flow is warm, however) When the temp lever is on cold, the blower moves massive amounts of air, probably triple the amount.
So my feeling is, the OUTSIDE air passage (not the internal pipes where the water flows) of the heater core has become blocked with debris somehow and airflow across it is very limited, thus producing very little heat.
Has anyone ever heard of this and know how to fix it without dismanteling the entire heater box? I was thinking about taping off all the dash outlets but one and blasting air backwards through the system with a backpack leaf blower to try to unblock the core.
Thanks,
Doug Davis
doug davis is offline
post #2 of 3 Old 12-05-2010, 07:47 PM
durango-bob
2006 WK
You could try removing the heater blower assembly and seeing if there is a pile of leaves and such inside that area. It's fairly easy to do this, just pull out the battery and it's right there.
durango-bob is offline
post #3 of 3 Old 12-06-2010, 06:34 AM Thread Starter
doug davis
t
Reverse heater lines at intake 4.2 (front to heater core/ rear to bypass port) Chris Aunchman YJ Wrangler Technical Forum 1 07-27-2010 02:16 PM
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 09:31 AM
heater motor upgrade (dont worry its not the usual question) speepdaedeesi YJ Wrangler Technical Forum 10 09-13-2009 09:48 AM
heater problem (not the usual) bently TJ Wrangler Technical Forum 1 05-07-2008 12:31 PM
heater problem StuckInMud94 TJ Wrangler Technical Forum 1 02-03-2007 04:53 PM
