Heater Help - JeepForum.com
post #1 of 2 Old 02-19-2009, 05:36 AM Thread Starter
jeepers2112
Heater Help
Hello All-
I have a problem with my heater controls, no matter what directional setting I have it on (floor,vent, defrost) the air only comes out the direct vents. Any help? I'm in Michigan and my feet are freezing!
Thanks
jeepers2112 is offline
post #2 of 2 Old 02-19-2009, 06:36 AM
Jackle
you either have a small vacuum leak (but usually it will force the air out the windshield vents) or more realisticly your blend door in your air ducts has come loose and it is blocking everything but your directional vents
Welcome to the forum......good to see another michigander on here haha
Jackle is offline
Heater Help!!! Eriq35 YJ Wrangler Technical Forum 15 11-25-2011 10:12 PM
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
heater poncerstj TJ Wrangler Technical Forum 7 02-02-2007 09:26 AM
Heater ? allmopar YJ Wrangler Technical Forum 3 01-29-2007 04:57 PM
