Heater..defrost and feet work, not face
| The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I posted this problem a few days ago, however was told to search the topic. I've searched relentlessly on here and can't find someone who has had a similar problem. I pulled the unit out and messed with some of the wires connections to see if they had come loose, but they all seemed fine. All speeds work; Will only blow on feet only or defrost/feet combo.
Anyone know where to go from here?
97 TJ, 2.5L, Auto, 4" lift Last edited by doubleup; 11-27-2007 at 11:28 AM.. |
#2 |
exact same problem.. been that way since i bought the jeep last january tho
so any help would be appreciated here as well.... |
#3 |
Jeep
You have a vacuum leak somewhere and it isn't opening and closing the evaporator case doors.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#4 |
even with the '97?
i could be very wrong, and am probably going to sound pretty stupid, so don't haze me guys, lol... but i thought having the slider function, and the earlier tj's there was a difference.... no? |
#5 |
Vacuum leak, wonderful. I'll look around and see what I can find. I've looked around the block for vacuum leaks and have been unsuccessful thus far.
97 TJ, 2.5L, Auto, 4" lift |
#6 | |
Jeep
#7 |
not to be a bringer of bad news but mine is the same way. the control arm connected to the flap that opens the vent broke on mine and the dealership wants $1,400 to repair it. STUPID PLASTIC!!
look under the driverside dash and you will find the three canisters opperated by vacume to open the flaps for your hvac unit. if one is disconected or broke thers the problem also look at the vacume lines if one is loose that might b your problem
When im given a stressful problem I handle it like a dog. I piss on it and walk away!! |
#8 |
JEEP FREAK
Yup, definitely sounds like a vacuum leak.
I've never encountered this problem, so I can't offer much help. Here's some info from the FSM: VACUUM SYSTEM Vacuum control is used to operate the mode doors in the heater-A/C housing. Testing of the heater-A/C mode control switch operation will determine if the vacuum, and mechanical controls are functioning. However, it is possible that a vacuum control system that operates perfectly at engine idle (high engine vacuum) may not function properly at high engine speeds or loads (low engine vacuum). This can be caused by leaks in the vacuum system, or a faulty vacuum check valve. A vacuum system test will help to identify the source of poor vacuum system performance or vacuum system leaks. Before starting this test, stop the engine and make certain that the problem isn’t a disconnected vacuum supply tube at the engine intake manifold vacuum tap or the vacuum reservoir. Use an adjustable vacuum test set (Special Tool C-3707) and a suitable vacuum pump to test the heater-A/C vacuum control system. With a finger placed over the end of the vacuum test hose probe (Fig. 8), adjust the bleed valve on the test set gauge to obtain a vacuum of exactly 27 kPa (8 in. Hg.). Release and block the end of the probe several times to verify that the vacuum reading returns to the exact 27 kPa (8 in. Hg.) setting. Otherwise, a false reading will be obtained during testing. VACUUM CHECK VALVE (1) Remove the vacuum check valve. The valve is located in the (black) vacuum supply tube at the intake manifold vacuum tap. (2) Connect the test set vacuum supply hose to the heater (natural color) side of the valve. When connected to this side of the check valve, no vacuum should pass and the test set gauge should return to the 27 kPa (8 in. Hg.) setting. If OK, go to Step 3. If not OK, replace the faulty valve. (3) Connect the test set vacuum supply hose to the engine vacuum (black color) side of the valve. When connected to this side of the check valve, vacuum should flow through the valve without restriction. If not OK, replace the faulty valve. HEATER-A/C CONTROLS (1) Connect the test set vacuum probe to the heater- A/C vacuum supply (black) tube in the engine compartment. Position the test set gauge so that it can be viewed from the passenger compartment. (2) Place the heater-A/C mode control switch knob in each mode position, one position at a time, and pause after each selection. The test set gauge should return to the 27 kPa (8 in. Hg.) setting shortly after each selection is made. If not OK, a component or vacuum line in the vacuum circuit of the selected mode has a leak. See the procedure in Locating Vacuum Leaks. LOCATING VACUUM LEAKS (1) Disconnect the vacuum harness connector near the back of the heater-A/C mode control switch on the control panel. (2) Connect the test set vacuum hose probe to each port in the vacuum harness connector, one at a time, and pause after each connection (Fig. 9). The test set gauge should return to the 27 kPa (8 in. Hg.) setting shortly after each connection is made. If OK, replace the faulty mode control switch. If not OK, go to Step 3. (3) Determine the vacuum line color of the vacuum circuit that is leaking. To determine the vacuum line colors, refer to the Vacuum Circuits chart (Fig. 10) or (Fig. 11). (4) Disconnect and plug the vacuum line from the component (fitting, actuator, valve, switch, or reservoir) on the other end of the leaking circuit. Instrument panel disassembly or removal may be necessary to gain access to some components. (5) Connect the test set hose or probe to the open end of the leaking circuit. The test set gauge should return to the 27 kPa (8 in. Hg.) setting shortly after each connection is made. If OK, replace the faulty disconnected component. If not OK, go to Step 6. (6) To locate a leak in a vacuum line, leave one end of the line plugged and connect the test set hose or probe to the other end. Run your fingers slowly along the line while watching the test set gauge. The vacuum reading will fluctuate when your fingers contact the source of the leak. To repair the vacuum line, cut out the leaking section of the line. Then, insert the loose ends of the line into a suitable length of 3 millimeter (1/8-inch) inside diameter rubber hose.
98 TJ |
#9 |
Awesome diagrams. You know if a regular vacuum gauge will work?
#10 |
duga boy wholesale mopar has the arms for the flappler for the heater box.
#11 |
yup, same thing happened to me the other week, vacuum......score one for the warranty!!!!!!!
Also while it was in, the said the rear pinion seal was leaking and replaced it..... total cost = $0 take advantage of it while i can i guess
2005 Red TJ 6 Cyl 4.0L Manual Transmission, D44 Rear, 3.73 Gearing 32x11.5x15 BFG MTs on 15x8 Ravines w/ Spidertrax 1.25" Wheel Spacers 2" RE BB, 1" PA BL, 1" MORE MML AtoZ Rockers, Uniden/2ft Firestick(stolen), Nth Degree Oil Skid, JKS Discos 1986 Red CJ-7 Spring '89 - Spring '96, R.I.P. Red Jeep Club Member #289 Pix |
#12 |
I had the same problem on mine (100% my fault) but I could hear the leak under the hood and finally found it.
#13 | |
-2003 Rubicon 4.0L with 5 spd- RE 3.5 standard lift, 33X12.50X15 Good Year MTR's, black crager soft 8's, Rokmen mercinary front bumper, warn winch, Alloy USA axle shafts, Warn Rear Bumper with Tire Carrier, Poison Spyder Customs Rocker Gaurds... More coming shortly... |
#14 |
Here's a thread with lots of good info. Skip down to post #14, there's some good troubleshooting info.
http://www.jeepforum.com/forum/f9/air-vent-problems-66176/ And $1,400 is absolutely ridiculous to fix the broken control arms. You can buy them at http://www.discountjeepparts.com/index.php/cPath/408_412 for $13.95 each. They're the last two items on that page. Installing them is a bit of a pain but when I did mine, I'd guess it was no more than two or three hours of labor. |
#15 |
Just checked and it is JP mag in there newest issue they have a write up on how to fix it for like $2.50!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
