Heater core walk through. Pictures Inside! - Page 2 - JeepForum.com
post #16 of 53 Old 01-14-2007, 07:24 PM
volsfan4life252
I need some help!!! I can't get my heater box out. My dash is completly out, but i can't figure out how to get out the heater box. i see the bolts and nuts sticking through the engine side of the firewall, but when i turn the nuts, the bolts spin too! I can't even see, little on get to the bolt heads on the other side to grab them.......any advice???
volsfan4life252 is offline
post #17 of 53 Old 01-15-2007, 11:16 AM
Ron McIsaac
Junior Member
They are studs (4ea) so doesn't matter if they both turn
Removed mine yesterday (97 TJ) without removing the steering wheel & complete dash panel.
Ron McIsaac is offline
post #18 of 53 Old 01-15-2007, 04:33 PM
volsfan4life252
Stud meaning threaded on both ends with a nut on both ends??? That explains why when i turn the nut, the bolt turns too, but i can't get the nuts off!!! What is the trick for them???
post #19 of 53 Old 01-15-2007, 08:24 PM
Ron McIsaac
Junior Member
No nut on orher end
Stud has fine thread on the firewall side ( where you can see inside engine compartment) and there is a course thread on the other end which screws into the plastic plenum these two threads are seperated by a hexagon fixed washer which seats against the plastic.
So if nut & stud are turning together it should come out with no problem
Could send a picture if you want ( just give me an e-mail address, as i seem to be unable to attach files over the allowed limit of 109K ( or somthing in that range)
post #20 of 53 Old 02-17-2007, 01:23 PM
quigtj
Watch the playoffs!
Heater Box
I seem to have found the end of the instructions...FSM is on the way...in the mean time, I'm at the point (I think) where I need to get the heater box out. Just want to make sure I have the correct bolts behind the firewall before I go taking them out...I don't mind spending hours ripping out my dash, but I'm not a mechanic and am not as comfortable taking out random nuts under the hood...Let me know...THANKS!!
BTW, Thanks to scorpionkill for this write-up!
'97 TJ Sahara, Black, 4.0L, 5SPD, Line-x
quigtj is offline
post #21 of 53 Old 02-17-2007, 01:45 PM
Scott00TJ
wow, if that doesn't look like a huge PITA. Easy to see why having a shop replace it is so expensive!
'42 Ford GPW |'00 Wrangler|'08 Grand Cherokee|'10 Patriot Latitude
Scott00TJ is offline
post #22 of 53 Old 02-17-2007, 03:20 PM
FL 4.0L
I haven't seen this job turn out to be easy in any vehicle. This part is so close to the firewall that I can't understand why there couldn't be a better design.
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #23 of 53 Old 02-17-2007, 03:25 PM
quigtj
Watch the playoffs!
It's definitely long, but I haven't found it all that troublesome other than not being sure which nuts to take out to get the heater box off...just long.
I'm learning a lot, that's for sure...
quigtj is offline
post #24 of 53 Old 02-17-2007, 04:52 PM
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Here is my fix...
Michael Ferrari
Team 120 - DOR Racing - Racing for Operation Homefront
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline
post #25 of 53 Old 02-18-2007, 12:15 PM
quigtj
Watch the playoffs!
Anyone?
Can anyone comment on my last post (quoted below)? I'm ready to go, but without the FSM or confirmation from one of you experienced guys, I've got to wait.
THANKS
quigtj is offline
post #26 of 53 Old 02-18-2007, 12:24 PM
jzmtl
jzmtl's Avatar
Originally Posted by mferrari
Here is my fix...
Dosen't seem to be nearly enough in -20 thou. Stock heater can make the (front part of) cabin unbearably hot even in that temp.
jzmtl is offline
post #27 of 53 Old 02-18-2007, 02:12 PM
quigtj
Watch the playoffs!
One more try
Ok, one more try on getting someone to take a look at the pictures and confirm the nuts are the right ones to take out to remove the heater box...
Much appreciation!!
quigtj is offline
post #28 of 53 Old 02-19-2007, 05:47 AM
quigtj
Watch the playoffs!
Last time I'll ask...
Are these the right nuts to pull off to get the heater box out?
Thanks and Happy Presidents' Day
quigtj is offline
post #29 of 53 Old 02-19-2007, 07:06 PM
quigtj
Watch the playoffs!
Update: Found one more behind the battery thanks to someone from one of the google groups. Also found a mount inside the cab near the fuses. The guys says there's one more somewhere??? Anyone care to let me in on the secret? The new core came today, I'm chomping at the bit!!!
quigtj is offline
post #30 of 53 Old 02-19-2007, 07:49 PM
Curly
Curly's Avatar
Holy Crap!!! And to think I was bitcching the whole 35 minutes it took me to do mine on my CJ7.
Curly is offline
heater core , replacement
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
Which Heater Core to Buy? WittSmall TJ Wrangler Technical Forum 2 02-23-2009 09:32 AM
*&%$@###*&! Heater Core finsout TJ Wrangler Technical Forum 5 02-13-2008 03:49 PM
Dam Heater Core !!! pelos YJ Wrangler Technical Forum 3 06-19-2007 10:08 AM
heater core Jeep444 TJ Wrangler Technical Forum 13 10-28-2005 04:14 PM
