Heater core hoses leaking - JeepForum.com
post #1 of 18 Old 11-20-2015, 12:11 PM Thread Starter
Leffnasty
According to the shop I dropped my jeep off at, my heater core hoses are leaking. They quoted me at just under $150. This smells fishy.
I won't be able to replace these for another two or three weeks, but it is a slow leak at the moment, been leaking for about two weeks.
What do y'all think? Too expensive? Can't wait that long? I know I could do it myself I just don't have the tools/space/time at school.
Leffnasty is offline
post #2 of 18 Old 11-20-2015, 12:30 PM
tucsonzj
considering parts and labor, probably a fair cost. is it difficult? no, but if you don't have the space or time to do it then what else are your options? I could easily see quoting an hour of labor and $50-60 worth of parts and fluids
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #3 of 18 Old 11-20-2015, 12:36 PM
JStMarie
JStMarie's Avatar
It's quite literally less than a 10 minute job and can be done while in the take out line at your local McDonald's.
It will probably take longer for me to write... yup, there it is, done.
All kidding aside, go grab the hoses, a screwdriver, a pair of channel locks, and a 50/50 mix of coolant and do it in the parking lot of the place you just bought those things.
Good Luck.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #4 of 18 Old 11-20-2015, 12:44 PM Thread Starter
Leffnasty
Great, I'll give them a call. Autozone parking lot will have a new stain once I look up some writeups.
Thanks y'all
Wow, just watched a 10 minute video while doing some homework at the same time. You weren't kidding, I could change those hoses in 5 minutes. $150 is insane. Once again thanks
post #5 of 18 Old 11-20-2015, 02:03 PM
JStMarie
JStMarie's Avatar
If there is any incline where you do it park nose down, it will reduce the spillage. Do one hose at a time and it shouldn't spill very much. Top her off and then run her up to temp when you are done to make sure nothing is leaking before you leave.
JSt.Marie
JStMarie is offline
post #6 of 18 Old 11-20-2015, 02:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Know ahead of time that the two heater hoses have two different diameters. I forget what they are but you will probably be able to read the diameters on the hoses. They were still legible on mine the last time I noticed.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #7 of 18 Old 11-20-2015, 02:25 PM
JBTJ
Just did mine a couple weeks back. 11/16th's and 5/8th's about $25 for the hose and about 10 minutes to swap them out.
JBTJ is offline
post #8 of 18 Old 11-20-2015, 02:32 PM
Jerry Bransford
Administrator
What I want to know is what genius engineer decided the two hoses should have a 1/16" diameter difference. I'm sure there's some hypothetical advantage having something to do with water velocity but sheesh.
Getting
post #9 of 18 Old 11-20-2015, 02:35 PM
JBTJ
Really
JBTJ is offline
post #10 of 18 Old 11-20-2015, 02:48 PM
Jerry Bransford
Administrator
Research discovered the engineer had some excess Cray supercomputer time available so he cranked up a computational fluid dynamics program and he discovered there was a slightly reduced coolant turbulence benefit to that 1/16" diameter difference that occurs when the tide is at low ebb and Jupiter is aligned with Mars.
Getting
post #11 of 18 Old 11-20-2015, 03:43 PM
2jhanna
Be carefull with the elbow nipple from the water pump. Very easy to rust out and can be fragile.
If it breaks, cracks, or twists, you want make it home.
jhanna
denton county, tx
2jhanna is offline
post #12 of 18 Old 11-20-2015, 03:48 PM Thread Starter
Leffnasty
Thanks for the tips. Should I replace the clamps with worm drive hose clamps or leave the stock ones?
post #13 of 18 Old 11-20-2015, 04:36 PM
Jerry Bransford
Administrator
Reuse the OE constant tension clamps which self-adjust their tension based on the temperature. They are not as likely to cause a leak as worm drive hose clamps are.
Getting
post #14 of 18 Old 11-20-2015, 04:54 PM
ravenworks
That and the fact they didn't want the hoses (direction of flow)mixed up.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #15 of 18 Old 11-20-2015, 08:54 PM
chris142
I'm not saying they can't be bad but a leaking heater hose is very rare on a TJ. I get jeeps in my shop with high mileages and the original hoses. The upper and lower hoses seem to fail more often than the heater hoses.
chris142 is offline
